Installing Fuel Tank and Fuel Lines? How Hard? - JeepForum.com
post #1 of 7 Old 01-10-2008, 09:33 AM Thread Starter
JeepFan07
I am going to look at a 76 Cj which does not have a fuel tank installed. Right now the owner has a gas can feeding it. I have never installed fuel lines or a fuel tank how hard of a job is this? Thanks for your help.
JeepFan07 is offline
post #2 of 7 Old 01-10-2008, 09:54 AM
Indy
Indy's Avatar
The tank should just bolt in and you can order pre-bent fuel lines. Kindo of a pita but not a major undertaking.
I'm the only gay eskimo.
Indy is offline
post #3 of 7 Old 01-10-2008, 10:03 AM Thread Starter
JeepFan07
do you know about what they run $$?
post #4 of 7 Old 01-10-2008, 10:51 AM
Hybrid Jeep
1976 CJ5
I am doing the same thing on a 1976 Jeep CJ5. You will need.. a replacement fuel tank (either junk yard or Quadratec sells replacement plastic tanks).
Keep in mind that if you don't have the factory fuel tank skid plate you will have to pick one up as thats how its mounted to the frame.
The easiest way to do it is pick up the kit (with sending unit and everything else you need):
http://www.quadratec.com/products/51306_13.htm
Then you will need the skid plate:
http://www.quadratec.com/products/51313_00.htm
Prebent Fuel Lines:
http://www.quadratec.com/products/51315_102.htm
http://www.quadratec.com/products/51315_202.htm
http://www.quadratec.com/products/51315_300.htm
Total in my shopping cart at Quadratec was $607.95 + $44.99 shipping.
Of course you can save a bunch of money by finding a good tank and skid plate at a Junk yard.. craigslist... etc. You can also save some cash bending the fuel lines yourself.
Good luck!
Hybrid Jeep is offline
post #5 of 7 Old 01-10-2008, 01:18 PM
HackFabrication
HackFabrication's Avatar
1976 CJ5
Ugh.
Did the PO chitcan the original filler tube/vent tube? The 76 has a big azz hose for the filler and a smaller hose that fits into a 'fitting' that is pressed into that big azz hose. But you're in luck. For some reason, the aftermarket makes a filler hose for the 76 Jeep (but not the 77-something I recently was told). And the small fitting? Junk yard.
Better to convert over to the 78-86 CJ style filler assemby:
Of course...You're gonna have to 'Hack Fab' it in with the later model tank.
As far as fuel lines go, you can order pre bent lines from a variety of sources...However, once you start 'upgrading' don't expect things to 'bolt in'.
Good luck.
"In the end...It's all Hack."
HackFabrication is offline
post #6 of 7 Old 01-10-2008, 04:21 PM
fuzz401
1978 CJ7
if needed I have my 15 gal tank and hoses that I just pulled out for 50.00 + shipping out of a 78
I am going to this instead
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #7 of 7 Old 01-10-2008, 07:49 PM Thread Starter
JeepFan07
Thanks so much guys that is a ton of help. I really appreciate it.
Bad TBI electronic fuel pump or problem with fuel tank? boomvader Jeep CJ Forum 5 01-18-2010 11:26 PM
Fuel float next to fuel tank migolito Jeep CJ Forum 4 01-10-2010 09:36 AM
INstalling Fuel sender unit in new tank ishcak Jeep CJ Forum 5 07-09-2006 03:04 PM
swapped fuel tank and no fuel at carb 8679cjs Jeep CJ Forum 6 12-05-2005 11:17 PM
fuel tank to lines? CJ7Laredo Jeep CJ Forum 3 03-21-2005 06:20 PM
