Installing AC condenser - JeepForum.com
post #1 of 7 Old 11-22-2012, 05:27 PM Thread Starter
sanddrag
To install an AC condenser (where there was never one before), is it easier to take out the radiator or the grille? Also, can the hoses be put on after it is installed or will the fittings be impossible to get to? Thanks.
sanddrag is offline
post #2 of 7 Old 11-23-2012, 06:01 AM
gmakra
You can just pull the radiator and install the condensing unit with the hoses attached.
gmakra is offline
post #3 of 7 Old 11-23-2012, 09:29 AM Thread Starter
sanddrag
The reason I was asking about hoses is I don't have them made up yet. I have to measure for length after the condenser is installed.
sanddrag is offline
post #4 of 7 Old 11-23-2012, 01:54 PM
gmakra
Length isn't that critical I would estimate a little on the long side and do it while you have the access.
gmakra is offline
post #5 of 7 Old 11-26-2012, 02:10 PM
wm69
Having done this, I'd remove the grill, bolt condensor in, then bolt in radiator, then bolt whole assembly back on the Jeep. Grill is easy to remove, and working on the condesor is a $^($* simply due to lack of room.
wm69 is offline
post #6 of 7 Old 11-26-2012, 05:26 PM Thread Starter
sanddrag
I ended up pulling the radiator and fan, and left the grill. No problem.
sanddrag is offline
post #7 of 7 Old 11-27-2012, 06:02 AM
h2ogun
This past spring, I had my condenser in and out looking for the best air flow. each time I pulled my fan and radiator. My hoses came in on the passenger side so I pulled the passenger side head light for easier access. Pulling the head light is very easy and made life better for me.
h2ogun is offline
