installed new ignition, carb & manifold on my 304 - JeepForum.com
post #1 of 5 Old 05-25-2004, 07:42 PM Thread Starter
Marc CJ7
Just got finished upgrading my stock 304 points ignition, 2bbl carb and manifold to a DUI, Edelbrock 600 cfm carb & performer manifold. Man what a difference, its like a totally new engine under the hood. Im able to spin the tires from a roll in 2nd gear .
Everything was running fine for the inital test drive, I went about 1 mile and came back home to clean up the tools and I jump back in to take another ride but I only made it about 50' and it dies on me. I think its electrical because the starter is spinning but its not sparking. I checked the jungle that I call the fuse block and found some fuses that looked broke so I threw new ones in there but still no spark??? Anyone have any ideas, I'm open for suggestions... even stupid ones.
Thanks
82 CJ7 - 304 / T5
98 GTI VR6
All Motor: 1.89 - 13.55 @ 101.60
Marc CJ7 is offline
post #2 of 5 Old 05-25-2004, 11:33 PM
CJ-5
New
check all the new stuff first, maybe you never tightened somthing down or somthing was not quiet plugged in all the way, and came loose on your little rip around the neighbourhood.
CJ-5 is offline
post #3 of 5 Old 05-26-2004, 07:09 AM Thread Starter
Marc CJ7
went over everthing again last night but didn't see what the problem was. Today when I get home I will use the multi-meter & test light to see what the problem is. I am almost 100% sure its spark related because the starter spins but the plug wires don't arch... still open for suggestions.
thanks
82 CJ7 - 304 / T5
98 GTI VR6
Marc CJ7 is offline
post #4 of 5 Old 05-26-2004, 03:51 PM Thread Starter
Marc CJ7
thanks
just wanted to add one question to the post, what kind of vacume advance system does a 304 have? The carb says there are 2 kinds (vacume advanced & something else I can't recall) of different systems, I just want to make sure I have my vacume hose coming off the D.U.I.
Thanks.
82 CJ7 - 304 / T5
98 GTI VR6
Marc CJ7 is offline
post #5 of 5 Old 05-26-2004, 06:58 PM Thread Starter
Marc CJ7
OK, I found the problem. The drive gear on the D.U.I. distributor is worn out, it probably happened when I started the jeep up the first time and didn't have the distrbuter clamped all the way down. It sounded like a crunching noise just like when it died on me yesterday. So does anyone know where I can get a new on of these??
where can I find a 304 AMC V8 D.U.I. distributor drive gear???
thanks.
82 CJ7 - 304 / T5
98 GTI VR6
Marc CJ7 is offline
Intake manifold and carb swap Jaxson09 Jeep CJ Forum 4 08-08-2009 12:55 AM
Challenging Carb/ignition problem. I'm stumped Brad79CJ Jeep CJ Forum 6 08-04-2008 09:48 PM
Carb and Manifold jeepvosser Jeep CJ Forum 4 08-07-2006 06:34 PM
Manifold+carb recommendations? vladrulli Jeep CJ Forum 7 07-12-2006 08:22 PM
need a new manifold & carb for the CJ Marc CJ7 Jeep CJ Forum 6 02-14-2004 10:16 PM
