Installed HEI dizzy-Jeep won't start? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Installed HEI dizzy-Jeep won't start?
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 04-27-2013, 12:46 PM   #1
my_304_cj7
1976 CJ7
Installed my HEI distributor today and now I get nothing when I turn the key. I ran power directly from the battery to ensure 12 volts but I have a lot of wires that aren't connected now from the old distributor and from the coil. Any idea where my issue is?
'76 CJ7 Quadra-Trac 304 2.5" superlift 1" body lift 33" DuraTrac's
2014 Grand Cherokee Altitude
my_304_cj7 is offline   Reply With Quote Quick reply to this message
Unread 04-27-2013, 01:22 PM   #2
86cj74.2L
86cj74.2L's Avatar
Do you have spark when cranking the engine?
Slowly move the distributor Untill it tries to start.
86cj74.2L is online now   Reply With Quote Quick reply to this message
Unread 04-27-2013, 01:45 PM   #3
my_304_cj7
1976 CJ7
It is not even cranking. I just went out and took the cap off and what I think is the coil is completely melted on one side.
Was my +12v supposed to connect to the terminal that said BAT or Coil?
Unread 04-27-2013, 01:53 PM   #4
my_304_cj7
1976 CJ7
Crispy!
Unread 04-27-2013, 02:15 PM   #5
hp_lovecraft
1981 CJ5
You wire the 12v to the "bat" to power it directly. The "coil" is for a tach, and is optional.
But since it won't even turn over, did you also burn out the solenoid? THe HEI is pretty simple, but I've had problems before from cheaply made parts. On mine, the plug would get bent, and I'd have to take it apart to fix. Maybe you shorted out something?
The good news is that "rebuild" kits for the HEI are pretty cheap on ebay. I think I paid $30 for one that included the cap/coil/rotor/module
hp_lovecraft is offline   Reply With Quote Quick reply to this message
Unread 04-27-2013, 02:21 PM   #6
swatson454
1983 CJ7
The other one Sorry, couldn't help it.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now   Reply With Quote Quick reply to this message
Unread 04-27-2013, 02:35 PM   #7
swatson454
1983 CJ7
Joking aside, I'm pretty sure mine said 'BAT' on the right and 'TACH' on the left. Did yours actually say 'COIL'?
Shawn
Unread 04-27-2013, 04:37 PM   #8
my_304_cj7
1976 CJ7
I had it wired to the one that said BAT. The other side says coil. I am going to chalk it up to cheap crap and have the seller send out another cap and try it again.
One other question. Are these distributors based on a factory model that I could just run to the auto parts store and pick up another cap?
Unread 04-27-2013, 04:55 PM   #9
swatson454
1983 CJ7
I can't believe yours said 'COIL'. Maybe I've lost my mind.
I don't know who made yours so I can't say for sure but all of the parts should be interchangeable from any Chevy V8 with a 4-pin module. Don't hold me to that, though
Shawn
