Install help-Weber 38 and Holley 12 804 fpr - Page 2 - JeepForum.com
post #16 of 26 Old 01-27-2013, 04:08 PM Thread Starter
Tubzcj
Dude I'm lost. I have read so many threads but I'm stuck... I just know that nipple at the carb base is stopping my linkage. I could flip it to the front facing the radiator..
The two holes that are on the valve cover.. Can I switch the pcv valve that was in the rear to the front?
Tubzcj is offline
post #17 of 26 Old 01-27-2013, 04:28 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Stop. Take a breath. And read this site.
Once you understand each vac system, you can pick and choose which ones to use, and how to hook them up.
Matt
Matt1981CJ7 is online now
post #18 of 26 Old 01-27-2013, 05:13 PM Thread Starter
Tubzcj
Ok got it figured out.. I just switched the plate around.... Now on initial crank it sounds good but I am not getting a reading on the fpr..
Tubzcj is offline
post #19 of 26 Old 01-27-2013, 06:07 PM Thread Starter
Tubzcj
The gauge is not reading is what I meant.
Tubzcj is offline
post #20 of 26 Old 01-28-2013, 05:00 PM Thread Starter
Tubzcj
Faulty gauge.. Works now..
Tubzcj is offline
post #21 of 26 Old 01-28-2013, 06:42 PM
cj5huntingrig
1974 CJ5
How is your Weber running? Any backfiring? I have a similar setup but I'm having timing issues due to loose sloppy timing chain. Working on that issue now.
By the way, PCV is not that big of a deal and yes, you can run it off of the air filter base nipple. Many many folks eliminate the PCV valve with few issues. It is still good practice to have some sort of vacuum into the filter box, but not that big of a deal.
All the best, Evan
1974 CJ5 all stock except for Rocky Road SOA
Completely for hunting - not for show or rock climbing
cj5huntingrig is offline
post #22 of 26 Old 01-29-2013, 11:44 AM Thread Starter
Tubzcj
It is running good. I really like the setup. I am having and issue with my vacuum advance and was going to wait till this weekend to try to figure it out. When I have the vac line ran to my DUI distributer it starts running like poo. I am kinda new at this so I am open to suggestions if you have any
Tubzcj is offline
post #23 of 26 Old 01-29-2013, 12:11 PM
Matt1981CJ7
1981 CJ7
Tub,
Do you have ported or manifold vac to the DUI? I believe it's suppose to have manifold.
Matt
post #24 of 26 Old 01-29-2013, 12:34 PM Thread Starter
Tubzcj
It is currently ported but after reading numerous threads I think I am going to go with the manifold. Also seen numerous people talking about 2 different slots on the DUI dizzys. I haven't noticed this before.
Tubzcj is offline
post #25 of 26 Old 01-29-2013, 12:38 PM
swatson454
1983 CJ7
And the cap needs to be mounted on the base with the wire hookups over the vacuum can, not clear over to the side. Like this...
If the cap is mounted the other way, the timing goes nuts when you hook vacuum up to it.
Shawn
Edit: I see you beat me to the punch
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #26 of 26 Old 01-29-2013, 01:17 PM Thread Starter
Tubzcj
Damn I love JF. Thanks guys will let you know how it works out.
Tubzcj is offline
carb , carburetor , fuel pressure regulator , weber
