Install help-Weber 38 and Holley 12 804 fpr - JeepForum.com
post #1 of 26 Old 01-26-2013, 01:33 PM Thread Starter
Tubzcj
Ok guys after doing a lot of research and reading tons of thread reading here I ordered the weber 38 (Spain), Holley 12 804 fpr, and a pressure gauge. Got home from running some errands and all of my parts where sitting on the porch. I have some questions and could really use the help from people that have ran this set up before.
newly built not driven.
258 punched 30/port and polished/performance cam/headman headers/DUI
1) will I need to order different jets then what are currently in the redline 38?
2) does the fpr need to be installed before or after the fuel filter?
3) fpr mounting options?
4) I have read mixed reviews about the mounting plates and gaskets leaking. What is the best route here?
5) tuning tips on the weber?
6) where is the best place to locate my hot wire for the EC?
Any help would be greatly appreciated
Tubzcj is offline
post #2 of 26 Old 01-26-2013, 01:57 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
1. The factory jetting is for a sea level application. I think it should be pretty close for you. I don't recall the jet sizes, but a few searches will turn up that info.
2. After.
3. See pic below. Not the most elegant homemade contraption, but it works.
4. I had mine on and off several times, even re-used the gaskets a few times. Never had any leaks. Just check that the mounting plate is flat and has no casting imperfections.
5. Search for a thread called Weber Set-up and Tune Discussion.
6. In the wiring harness. (Your manual's wiring diagram should show it.)
Good luck,
Matt
Matt1981CJ7 is online now
post #3 of 26 Old 01-27-2013, 08:00 AM Thread Starter
Tubzcj
Thanks dude. Going to do it today?
Tubzcj is offline
post #4 of 26 Old 01-27-2013, 02:17 PM Thread Starter
Tubzcj
There is a nipple that the instructions have label as power brake fitting that is stopping the flow of my linkage. When I took off my old carb the line ran to the top of the valve cover?
Can I plug this? I have a brake booster ???
Tubzcj is offline
post #5 of 26 Old 01-27-2013, 02:19 PM Thread Starter
Tubzcj
Bracket turned out nice.
Tubzcj is offline
post #6 of 26 Old 01-27-2013, 02:33 PM Thread Starter
Tubzcj
This isn't threaded and I feel that I need to plug it. Just tap it ??
Tubzcj is offline
post #7 of 26 Old 01-27-2013, 02:39 PM
Matt1981CJ7
1981 CJ7
Nice bracket!!
I can't believe someone actually copied my redneck design.
Is your PCV hooked-up to a manifold vac source on your carb? Are you running the charcoal canister? EGR? TAC? CTO?
Matt
post #8 of 26 Old 01-27-2013, 02:44 PM
Matt1981CJ7
1981 CJ7
Mine didn't need a plug.
Matt
post #9 of 26 Old 01-27-2013, 03:11 PM Thread Starter
Tubzcj
This is what was running off of my old set up from the pcv. I have seen some people on here and they have picture of this plugged.. I Eliminated all emissions equipment since I live in GA.
So can I plug the power brake fitting-is what weber directions is calling this? I have a port coming off of the intake going to the brake booster. The port is directly under the carb..
Tubzcj is offline
post #10 of 26 Old 01-27-2013, 03:12 PM Thread Starter
Tubzcj
Port
Tubzcj is offline
post #11 of 26 Old 01-27-2013, 03:24 PM
Matt1981CJ7
1981 CJ7
So you have no PCV? How are you venting the crankcase?
post #12 of 26 Old 01-27-2013, 03:32 PM Thread Starter
Tubzcj
I do have a pcv it was ran to this nozzle that is stopping my flow on my linkage. I would like to eliminate that nipple and just put a filter on top to the valve cover.. Thoughts?
Tubzcj is offline
post #13 of 26 Old 01-27-2013, 03:46 PM
Matt1981CJ7
1981 CJ7
You still need a vacuum source to pull fresh air thru the filter into the crankcase.
post #14 of 26 Old 01-27-2013, 03:49 PM Thread Starter
Tubzcj
I have the unit on the front end of valve cover that runs to the carb. This picture is where the pcv was ran from the front. Will that suffice?
Tubzcj is offline
post #15 of 26 Old 01-27-2013, 04:00 PM
Matt1981CJ7
1981 CJ7
Suffice for what? That's not a vacuum nipple.
You do understand how the PCV works, don't you?
Matt
carb , carburetor , fuel pressure regulator , weber
