Install of Aluminum Valve Cover - JeepForum.com
post #1 of 17 Old 07-17-2006, 12:13 AM Thread Starter
Vonster
Need some help with the installation of my new aluminum valve cover. I have tried the valve on for size a ‘dry fit” and it fits perfect.
First, before I continue the instructions I have are crap and I haven’t found anything on any online forums that help so I’m giving this a try before I take in somewhere. Second, everything I have found leads me to believe that every 258 made is different.
I know the valve cover fits and I know all of the holes line up perfect. However, the two holes on the driver side are not deep enough and are not threaded (this is the side near the intake manifold). I’m not sure what these holes were used for but I want to use them for my valve cover ( I read this what I should do). My question is how deep can I drill these holes so that I can use them so nothing gets franked up? Second, can you use RTV on the cork gasket or not? I have heard not to and I have heard its OK…HELP ME….
Vonster is offline
post #2 of 17 Old 07-17-2006, 12:38 AM
1bflm
I did some searchin and came up with the following web site that does a step by step on what you have to do. There is a "Notes" section that has some pretty good descriptions on what to watch out for.
http://www.skidmore.edu/~pdwyer/amc/...valvecover.htm
I hope this helps I if you have an issue getting to it I can post the step by step for you. Good luck!
1bflm is offline
post #3 of 17 Old 07-17-2006, 12:55 AM
Galt
Galt's Avatar
1983 CJ7
I just installed one about a month ago. You do have to tap those two holes on the drivers side. I went to far and had to repair it. I broke through into the coolant passage. Whoops. It was an easy fix with some epoxy putty but it would have been better if I didn't have to go through all that.
If you only drill down about a 1/2" you should be fine. Be real carefull though. I would suggest using a dull drill bit. You know how a sharp one likes to get ahead of itself if your not real cautious. I did use RTV on the cork gasket. It's sealing fine. I also did not bother with the nut on the backside by the firewall. It is a PITA to get to.
Have fun.
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
1993 RX7 1.3L Rotary/ GT40R turbo/484 rwhp
2002 F-150 Lariat 5.4L V8
2007 GMC Yukon Denali 6.2L V8
Galt is offline
post #4 of 17 Old 07-17-2006, 01:23 AM
bdmonist
WTF is that?
bdmonist's Avatar
You could cut off your studs to fit, find shorter studs, or use washers if you are uncomfortable drilling the holes deeper. You won't have to worry about driling too far down if you're not drilling! I would place the RTV on the valve cover, then set the cork gasket on the RTV, let it set for about 45 minutes, then install. I did mine this way and it helped keep the gasket in place where I wanted it while installing it on the head. Tighten the bolts a little at a time and you're good to go
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline
post #5 of 17 Old 07-17-2006, 02:17 AM Thread Starter
Vonster
Thanks!! I appreciate the assistance from everyone.....I will give it a go with a dull drill bit to about 1/2" below the bottomof the hole but I will use shorter bolts.
Vonster is offline
post #6 of 17 Old 07-17-2006, 02:43 AM
wm69
I've put two of these on and didn't drill either one any deeper, just got shorter bolts from lowe's. Get a bottom tap, tap the two holes without drilling them any deeper, get shorter bolts, use RTV, and bolt it on. DON"T overtighten the bolts or you'll crack your valve cover. No more leaks.
wm69 is offline
post #7 of 17 Old 07-17-2006, 02:45 AM
Shameless Elmer
83 CJ5
1983 CJ5
Before you start drilling, stick the drill bit into the existing hole in the head. Wrap a piece of tape, duct tape, masking tape or electrical tape 1/2" above the point where the top of the hole meets the drill bit. Put the drill bit in the drill motor and drill the head until the tape reaches the top of the hole. Also, since you have the hole depth marked with tape, go ahead and use a sharp drill bit to make the drilling easier. Be sure to use some lubricating oil while drilling to keep the bit cool.
Be sure to use a "bottoming tap" when you tap out the hole, therwise the threads won't be cut all the way to the bottom of the hole. A "bottoming tap" will be flat on the end, as opposed to having a point on the end.
Also, be sure to cover the area under the valve cover so none of the drill shavings drop into the engine.
Shameless Elmer is offline
post #8 of 17 Old 10-07-2010, 03:27 PM
jatepper
Old thread, but I am awakening it. Anyone know off hand what size tap I need to buy? I'm hoping to stop by lowes in about 20/30 mins.
Thanks.
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #9 of 17 Old 10-07-2010, 03:33 PM
iluvcowjuice
1979 CJ7
If you click the link in the 2nd post it says a 1/4" by 20.
iluvcowjuice is offline
post #10 of 17 Old 10-12-2010, 01:21 PM
twoscooterz
Can I get the right allen head bolts @ Home Depot of Lowes? Does the grade or finish matter?
'86 CJ7 Laredo, 258, Weber 38, DUI, T5 w/Hurst shifter, 4.56 Dana 30, AMC 20, Detroit TruTrac, Moser axles & Blue Torch truss, Dana 300, stock YJ springs SUA, 33" MTR's, Poison Spyder sliders, NewGen tank cover, Warn 9.5ti w/synthetic rope
twoscooterz is offline
post #11 of 17 Old 10-12-2010, 06:02 PM
Torxhead
Usually when you purchase those Allen head bolts, they come with a black oxide finish. Theres usually enough oil leaking around there to get on them and prevent any rust. All the ones I have seen are made to Grade 8 standards, that should not be a problem anyway, because they don't get that tight. Clean out the hole and use locktite. Most any hardware store should have them.
Torxhead is offline
post #12 of 17 Old 10-12-2010, 06:31 PM
mcmud
1983 CJ8
I'd like to point out that while some may not most of the aftermarket V/covers will have flanges adequate for the original large washer nuts to hold the drivers side down omitting the need to bore and tap those two holes.
For instance the one pictured in post #3 seems to be a good example. Notice the width of that flange at the studded head bolts.
mcmud is offline
post #13 of 17 Old 10-12-2010, 09:53 PM
jatepper
My valve cover flange was indeed big enough and I could have used the nuts that go on to the threaded head studs on the driver said, but in my opinion it is not the best idea. I'm sure the Jeep engineers know more then I do, but to me it never made sense to do it like this in the first place.
Took me all of 10 minutes to tap out the holes on the driver side and I was good to go.
jatepper is offline
post #14 of 17 Old 10-14-2010, 07:38 AM
twoscooterz
I am getting ready to install an aluminum cover. Where can I get a bottom tap? Napa?
post #15 of 17 Old 10-14-2010, 07:52 AM
benullman
1981 CJ7
Have fun.
not to hijack but, why so you have your heater core hose going to the right side of your jeep? you have a great looking setup (similar to mine) and mine hang down on the left.
Ben
benullman is offline
New aluminum valve cover sstumble Jeep CJ Forum 24 12-07-2009 05:16 PM
Aluminum valve cover on the 258 mmerlina Jeep CJ Forum 13 02-09-2008 06:24 AM
aluminum valve cover?? KINGJRK1974CJ5 Jeep CJ Forum 12 01-15-2008 08:47 AM
Which Is The Best Aluminum Valve Cover dhood Jeep CJ Forum 4 09-12-2007 12:36 PM
Aluminum valve cover DustinsCJ7 Jeep CJ Forum 12 10-19-2003 10:46 PM
