Input shaft swap - JeepForum.com
post #1 of 12 Old 05-16-2013, 05:46 PM Thread Starter
wb3eim
1951 CJ3A
Input shaft swap
Will an input shaft from a T-86 fit in a T-15? Thanks!
wb3eim is offline
post #2 of 12 Old 05-16-2013, 06:57 PM
Brewski
No. T-15 parts are still out there but tough to find. I would be careful buying T-15 parts. You will end up with way more in the thing than worth and could swap to a more available setup for less. T-15's are as tough as nails, just getting more scarce.
Brewski is offline
post #3 of 12 Old 05-17-2013, 06:06 PM Thread Starter
wb3eim
1951 CJ3A
I made a mistake it is a T14 transmission. I am trying to use this trans to replace the T86 behind my Dauntless V6. Will the input shafts interchange. The T14 was behind a 232. Thanks!
wb3eim is offline
post #4 of 12 Old 05-17-2013, 08:58 PM
CSP
No they won't.
CSP is offline
post #5 of 12 Old 05-17-2013, 10:08 PM
80cj
80cj's Avatar
1980 CJ5
Dauntless V6 trannies require a longer input shaft than the AMC straight 6 engines.
80cj is offline
post #6 of 12 Old 05-18-2013, 08:19 AM Thread Starter
wb3eim
1951 CJ3A
What shaft would work? Does Advance Adapters make one?
wb3eim is offline
post #7 of 12 Old 05-18-2013, 10:27 AM
CSP
You need either a T14 or a T86 from behind another 225. Input shafts are not swappable between different transmissions.
CSP is offline
post #8 of 12 Old 05-19-2013, 05:54 PM Thread Starter
wb3eim
1951 CJ3A
I guess I'll buy an input shaft for the t14 but made for the 225 v6. I can get one for around a $100. Cheaper than rebuilding the t86. Thanks All.
wb3eim is offline
post #9 of 12 Old 05-19-2013, 10:59 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Be advised, the T14 is a marginal transmission at best, and they don't hold up well behind the Dauntless. I believe you can replace the T86 guts with those from the T90. This may be a better option. You can check up on parts on the erlycj5.com website, or contact hermtheoverdriveguy.
jeepdaddy2000 is offline
post #10 of 12 Old 05-20-2013, 07:00 AM Thread Starter
wb3eim
1951 CJ3A
I was going with the t14 because I thought it was an upgrade from the t86. If it's not I will stick with the t86. The Advance Adapters tech vault says the t14 is better for the v6 conversion so I am a little confused. Any thoughts?
wb3eim is offline
post #11 of 12 Old 05-20-2013, 05:26 PM
jeepdaddy2000
1971 CJ5
The T/86/90 is a stronger transmission by far, however, it is a bit balky to shift and you do not get a syncro'd first gear. The T14 shifts better, but they are simply a weak unit and do not hold up well behind the torque put out by the V6. I have seen a number of them break, including my own, which is why I went to the T18.
As far as the tech vault, they may be referring to the ease of adaping of the transmission, not it's strength.
post #12 of 12 Old 05-23-2013, 03:27 PM Thread Starter
wb3eim
1951 CJ3A
If I stick with the t86 will the dana 20 transfer case fit?
wb3eim is offline
