Inline Tube Fuel Question - JeepForum.com
post #1 of 4 Old 05-03-2010, 11:11 AM Thread Starter
Hybrid Jeep
1976 CJ5
Hey guys.. I ordered Inline tube's stainless brake lines for my CJ5 and was quite pleased with them..
So I took at look at their website and it shows 3 lines for fuel. One main line, one return.. and a "Fuel Vapor Line Canister 1pc 5/16". What line is this? I remember in the tear down having the main and the return.. but can't remember what this fuel vapor line canister line is.
Also.. it has two sizes for the main 5/16" and 3/8". I think stock lines were 5/16".. wouldn't a larger line cause less fuel pressure?
Hybrid Jeep is offline
post #2 of 4 Old 05-03-2010, 11:33 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
No the larger would allow better fuel delivery. The mechanical fuel pump uses suction to draw fuel up to it, then the pressure is from the pump to the carb. With the larger line, fuel would flow easier up to the pump. Even if you have an electric pump, mounted somewhere inline, the larger tube would allow easier flow. Try blowing thru a 1/4 inch line, then try it with a 1/2 inch line. Same principal.
Do you happen to have a link for them? I'd like to run stainless, but thru 4wd Hardware it is almost $100 per line. Are they any better in price?
Rick
Cutlass327 is online now
post #3 of 4 Old 05-03-2010, 11:51 AM Thread Starter
Hybrid Jeep
1976 CJ5
Inline tube is recommended for brake / fuel lines as they are better quality than what 4wd offers. Inline Tube - Preformed Stainless & OEM Brake Line Sets.
I've read horror stories of lines not fitting when ordered elsewhere.
Do you happen to know what that third line is for?
By the way.. my total was... $305.59 for the full CJ5 stainless brake line set.. a Disc/Disc prop valve, and the electrical connector for the prop valve.
post #4 of 4 Old 05-04-2010, 12:18 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Mine has the one from the charcoal can to the tank (vent), a fuel return line from the fuel filter (the little nipple) and then the main fuel line. Your '76 may not have a charcoal canister (emissions equipment) either from the year or previously removed. If yours doesn't have a charcoal can, then I wouldn't worry about it. I'd definitely put the return line and a return system fuel filter on if it doesn't have one - saves frustration from vapor lock.
Rick
Fuel Sending Unit and Fuel Injection Question CJman77 Jeep CJ Forum 4 12-21-2009 06:01 PM
New fuel lines - sections or one long tube? imtheant Jeep CJ Forum 2 02-28-2009 06:44 PM
Fuel injection on the inline 6 or small block chevy??? ProjectCJ5 Jeep CJ Forum 2 10-23-2008 12:18 AM
Inline Tube Keith Jeep CJ Forum 4 07-31-2008 02:43 PM
258 inline six valve cover question wiggs Jeep CJ Forum 2 03-03-2003 05:29 PM
