Indicator lights - JeepForum.com
post #1 of 3 Old 09-22-2013, 08:32 PM Thread Starter
war6191
1979 CJ7
Indicator lights
My 79 CJ7 has newer T176/D300 gear boxes. Anybody know anything about indicator system for fourwheel drive dash lighting? Can't seem to find much on this subject.
I think there is a spot on the main gauge for a 4X4 lite, am I correct?
war6191 is offline
post #2 of 3 Old 09-22-2013, 08:42 PM
80-CJ-5
1980 CJ5
On my cj 5 it is in the speedometer
80-CJ-5 is offline
post #3 of 3 Old 09-22-2013, 10:33 PM
lucdog
lucdog's Avatar
1980 CJ5
Yes and no, '79 came with a Dana 20 transfer case. No 4wd light was used. The yes part is the speedometer unit does have a provision for a light. It was used with a automatic tranny and the Quadratrac transfer case. When lit the spot on the speedo shows E drive.
The switch on the transfer case goes to ground,when you shift to 4wd. The light in the speedo already has 12 volts postive. So the switch sends 12 volts negative to the light. Use a mirror to look at the back of the speedo, there should be a open spot on the bottom, shine a flash light in the hole to check.
You will need a light socket with 2 wires, one for the wire from the switch, the other for 12 volts postive with the key in the run position.
The indicator light will be on the bottom left or right. I forget which one. The other one is for the brake warning light/emergency brake.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
