Ignition Upgrade '78-'90 Jeep, TeamRush Upgrade... - Page 3 - JeepForum.com
 2Likes
post #31 of 61 Old 10-24-2012, 12:09 PM
MaddBones702
Originally Posted by Davethewaveman
Hi guys and Jeephammer...I've read and re-read the teamrush and this thread several times. I live outside the U.S. so getting the parts and accesories is very tough for me, but my 83 CJ7 258 hopefully will be with me for years to come, so I'm trying to do everything right.
I team-rushed with Bosch cables, the Ford cap, new rotor, imported di-electric grease and never-sieze. I am not mechanically intelligent, but I work with my local mechanic, using the forum and translating everything for him.
I had motorcraft plugs for the last 4 years, but recently one fouled and I decided it was finally time to install the new autolite plugs that were recommended in the teamrush thread. I gapped them at .044 and decided to finally install my E-Core coil bought from Summit. Jeep lost power and my mechanic was convinced that the bigger gap plus coil had been too much for the factory module, so we installed the summit cdi.
The Jeep starts like never before...and it idles great. But around what I guess is 2000-3000 rpm (the tach stopped working with the cdi box and it takes a while to import new stuff) starts misfiring. We've tried to adjust timing, move the timing advance vacuum hoses from the carb, remove them, etc. but we can't get the Jeep to run well. It doesn't have much power. My mechanic had the Jeep for the last couple days and told me the only thing he can figure out is that the distributor is failing. He says it's not in very good shape. It seems to be the original, now 30 years old. So here are my questions:
1. Should I get buy an new distributor, and if so, should I stick with a rebuilt cardone, factory, or invest in something like the summit model for $150? Seems like JH says factory. Is this it? http://www.summitracing.com/parts/AAZ-30-4691/?rtype=10
2. The harmonic balancer is worn out, in bad shape, doesn't show TDC. Should I get a new one, if so, which one do you recommend? Dorman? Omix? Crown? Should I buy the MSD timing tape kit for it, or does it come with that? Do I need to buy a harmonic balancer puller? Which do you recommend?
3. I'm going to buy and install the OEM tachometer. With the summit box that I have SUM-850610 (I took it apart and the guts have the MSD logo!) which tach adapter will I need?
4. Based on other stuff I've described, do you guys have any other recommendations? I really appreciate it, I know everyone is busy and responding to this is a time investment, but I really need help and hopefully your response will help others in the future!
jH recommends the factory dizzy
I used a crown harmonic balancer and you will need a puller
I have MSD ignition and couldn't get the tach to work so I went with auto meter
Who knew where this would go?
MaddBones702 is offline
post #32 of 61 Old 10-25-2012, 06:16 AM
Davethewaveman
1983 CJ7
Should I bring some motorcraft spark plugs and try to go back to that? Could it be the Bosch cables that I bought a year and a half ago aren't heavy duty enough and I need to get the MSD cables cut to fit that JH mentions earlier in the thread??
Davethewaveman is offline
post #33 of 61 Old 10-25-2012, 08:28 PM
MaddBones702
I would first make sure you have the plug wires on correctly to the dizzy. Wires shouldn't be causing that much havoc.
post #34 of 61 Old 10-25-2012, 08:30 PM
MaddBones702
You may also want to start a new thread to get more attention. May be the fact that the thread is a year old people don't pay attention.
post #35 of 61 Old 10-26-2012, 04:30 AM
86cj74.2L
86cj74.2L's Avatar
Make sure the pickup wires between the distributor and CDI box are well clear of the spark plug wires.
86cj74.2L is offline
post #36 of 61 Old 01-05-2013, 11:10 PM
dharri770
1978 CJ5
woohoo! Followed JeepHammer's direction to a T. What a difference! I was really struggling with cold starts...this was a huge change. Thanks for the detailed posts and pictures!
dharri770 is offline
post #37 of 61 Old 01-06-2013, 05:43 PM
Kpkelly83
1983 CJ7
Dharri770 ...what plug wires did you end up going with? I am a little confused with what wires to use...Ford or Jeep (CJ or Cherokee)? Itnlooksnlikenthe CJ distributor cap uses different wires than the Ford but the lengths will be off as well.
Kpkelly83 is offline
post #38 of 61 Old 01-06-2013, 07:06 PM
86cj74.2L
86cj74.2L's Avatar
I used Bosch premium wire set from autozone for a 1995 jeep wrangler 4.0L.
post #39 of 61 Old 01-07-2013, 08:54 PM
dharri770
1978 CJ5
I used the red MSD wires from Summitt racing and the cap-a-dapt also from summit racing.
post #40 of 61 Old 05-04-2013, 01:35 PM
BantamTJ
1979 J-Series Truck
Great thread!!! I've just acquired all the components to do the Team Rush Upgrade on my 360. Currently the engine has a Mallory Unilite (non-vac) dizzy, I'm going back with the stock Motorcraft when I upgrade, also the PO has the ballast resistor wired in at the coil MSD Blaster (canister), will I need to ditch the BR or continue to use it?
TIA!
BantamTJ is offline
post #41 of 61 Old 05-04-2013, 05:26 PM
BantamTJ
1979 J-Series Truck
More in-depth research yielded yet another great post from jeephammer:
http://www.jeepforum.com/forum/f8/ms...istor-1303721/
Thanks JH!!!
BantamTJ is offline
post #42 of 61 Old 05-04-2013, 06:08 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
TIA!
Why? Going back to the stock distributor isn't an upgrade from a Unilite. You're going backwards.
I asked a ref if he could give me a technical foul for thinking bad things about him. He said, of course not. I said, well, I think you stink. And he gave me a technical. You can't trust em. -
Jimmy V
Pacfanweb is offline
post #43 of 61 Old 05-04-2013, 08:54 PM
BantamTJ
1979 J-Series Truck
Because its the recommendation from the Unilite that has only mech advance and I need vacuum to start with.
BantamTJ is offline
post #44 of 61 Old 05-05-2013, 10:45 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
I guess you might need vacuum if you have a basically stock motor. Not so much if you have a hot one in there.
An HEI would be a lot less trouble. It's an entire new ignition in one. Hook power to it, set the timing, and you're done. No muss, no fuss. The other way is a lot more work, and not really cheaper since you have to replace everything anyway.
Jimmy V
post #45 of 61 Old 05-05-2013, 01:48 PM
BantamTJ
1979 J-Series Truck
True, I DO need vacuum given the type of driving I do, and my engine is mostly stock with an RV cam.
Not looking so much for a plug-n-play quick fix but rather an overall ignition upgrade. Read up on Team Rush 304-360 ignition upgrade and you'll see why I decided this route would be best for me.
Thanks
BantamTJ is offline
jeephammer v8 teamrush 304 to 360 ignition upgrade oxynerd Jeep CJ Forum 27 11-12-2014 07:51 PM
Next step Team Rush upgrade ignition upgrade tevans59 Jeep CJ Forum 7 03-29-2010 05:39 PM
What is a TeamRush upgrade ? tevans59 Jeep CJ Forum 6 01-11-2010 07:02 PM
teamrush upgrade on 77 jeep with breaker points 89s15 Jeep CJ Forum 2 08-30-2008 12:01 AM
Teamrush upgrade on 76 CJ5 76silvercj5 Jeep CJ Forum 9 08-26-2008 04:49 PM
