Ignition system problem - JeepForum.com
post #1 of 24 Old 07-28-2010, 01:18 PM Thread Starter
75CJLevi
1975 CJ5
I have an issue with my ignition system. I recently encountered a problem where the engine runs rough and sputters and chugs on acceleration and misses at speed. While it was at the mechanics he was poking around with his voltage tester and found that when he poked the neg. terminal of the coil the engine reved up to normal speed and stopped sputtering. He had the timing light hooked up as well and the missing stopped and started running normally. As soon as he took it off it started running poorly again. I thought it might be a bad coil so I replaced it. But the new one did the same thing. I checked the ground wires and it didn't make a difference when i jumped a new ground.
Not sure what the deal is. Any help would be greatly appreciated.
1975 CJ5 Levi Edition, 304 V8 AMC; Blue with denim seats.
75CJLevi is offline
post #2 of 24 Old 07-28-2010, 02:06 PM
howelljeep
1979 CJ5
What did the mechanic say?
1982 CJ8
1979 CJ5 258 I6 3 speed
1999 Dodge Durango
howelljeep is offline
post #3 of 24 Old 07-28-2010, 03:02 PM
Shiftace
1977 CJ5
Sounds like a resistor. I had an old Dodge that did similar things. Turned out to be a little white ceramic resistor with a coil of wire running up the middle of it mounted on the firewall.
Shiftace is offline
post #4 of 24 Old 07-28-2010, 03:50 PM
248107
Guest
1983 CJ7
If you follow the wiring print the ground wire goes back to the ignition module.Do you have one?It should be on the drivers side fender or follow the wire back to it.Possible that it could be bad
Mike
248107 is offline
post #5 of 24 Old 07-28-2010, 05:20 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Try temporarily gounding the ignition module back to the battery. This diagram shows how poorly grounded the module is (to the distributor).
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #6 of 24 Old 07-28-2010, 05:30 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Here's a set of other diagrams, compliments of JeepHammer. The second diagram shows the suggested ground.
Ken4444 is offline
post #7 of 24 Old 07-28-2010, 10:38 PM Thread Starter
75CJLevi
1975 CJ5
He is just as stumped. He said that he has never seen any thing like this before.
75CJLevi is offline
post #8 of 24 Old 07-28-2010, 10:49 PM Thread Starter
75CJLevi
1975 CJ5
Thanks all!
I will take the diagrams to the mechanic and have him add the ground. I don't have a resistor on the jeep so it sounds like I need one.
75CJLevi is offline
post #9 of 24 Old 07-29-2010, 11:12 AM
JeepHammer
Running On Empty...
1973 CJ5
So when he probes the 'Green' coil terminal, the miss stops?
Sounds like you might need to work on that connection.
Terminals at the coil are a large problem, there isn't a summer goes by without me replacing two or three coil connectors because they give up.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #10 of 24 Old 07-29-2010, 03:35 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
I even had a problem with a new connector; one of the metal terminals had popped out of place and I didn't realize it. The Jeep wouldn't start. I went back to check the basics and happened to notice that the new coil connector had crapped out. It was esay enough to fix, but unfortunate that a new part malfuncitoned.
Ken4444 is offline
post #11 of 24 Old 07-29-2010, 04:28 PM
82JeepCJ7
1982 CJ7
If you Jeep does not have the ballast resistor, Chances are it never had one. My 82 never had one in the system.
82JeepCJ7 is offline
post #12 of 24 Old 07-30-2010, 09:56 AM
JeepHammer
Running On Empty...
1973 CJ5
'78 to '86 Jeeps (and beyond) all had ignition resistors.
It is a wire in the harness instead of the ceramic block most people are used to seeing.
Motorcraft/Duraspark won't live without one.
1.35 Ohms or better...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #13 of 24 Old 11-21-2013, 11:10 AM
semihemi
I wish someone had answer for this problem, I have the exact same symtom, 1975 cj w/258 prestolite ignition, I have replaced gas fouled plugs, replaced carb power valve, coil, module twice, distributor, added 3 grounds, isolated the alternator (rfi). When I touch test light to the neg side of coil the engine will start and run normal, without the test light it is hard starting, rough running, irratic ignition. All of the coils I have seen listed are USE WITH EXTERNAL RESISTOR. This ignition doesn't seem to use an external ballast or resistor wire, so im still at a loss as to why it shouldn't have a internal resistor coil installed.
semihemi is offline
post #14 of 24 Old 11-21-2013, 11:17 AM
CSP
The fix for '75-77 ignitions is just to get rid of the Prestolite ignition system and swap in something else, whether it's the '78 and up system, an HEI distributor, or an aftermarket system.
A good chunk of what was said in this thread (including the wiring diagrams above) isn't applicable to the '75-77 ignition system, which is just garbage.
CSP is offline
post #15 of 24 Old 11-21-2013, 02:35 PM
shadoow
can the mechanic repeat his 'success' ?? then use that to narrow down what causes the improvement
shadoow is offline
coil , coil terminal , connection , ignition , terminals
New Ignition System tshuelsman Jeep CJ Forum 13 04-26-2009 11:59 AM
Ignition system upgrade? aaveryy Jeep CJ Forum 17 07-15-2008 08:05 AM
anyone use MSD Ignition system grady adams Jeep CJ Forum 15 10-22-2004 06:53 PM
Ignition system problem BIGJMCCONNELL Jeep CJ Forum 4 12-30-2003 08:15 AM
HEI ignition system gumby Jeep CJ Forum 1 11-28-2002 08:10 AM
