ignition switch wiring for 1975 CJ - JeepForum.com
post #1 of 3 Old 04-25-2006, 02:33 PM Thread Starter
spearhunter
spearhunter's Avatar
1975 CJ5
Well, guys, my factory service manual has pretty diagrams but they don't really have anything on this one (crucial) switch. Apparently, I got an extra page on cherokees instead.
I've got a diagram of the back of the switch, including labelling. None of it is as obvious as I'd like, so I am hoping some of you can look at it and tell me what goes where. I numbered each of the 10 tabs and included the labels from the back as close to their original position as possible.
The only thing that makes sense to me is where the main line feeds in from the battery. For the ignition, I have no idea what grounds (if anything), what goes to the coil, and which ones aren't even used. Accessory, I have even less of a clue unless. Also, where it says GRD, is it referring to the little unused socket or is it referring to the top two tabs on the accesory side?
I'll post on a couple of other boards in case you guys don't have anything on it.
spearhunter is offline
post #2 of 3 Old 04-25-2006, 03:09 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Well for starters I would say
4-S1 goes to the starter solenoid.
10-Unused
1-unused
7-unused
6-unused
3 to battery
9- to fuse box
2 to fusebox voltmeter (+)
8 to tach or ignition coil (+)
5 to alternator , fuse box
John Strenk is online now
post #3 of 3 Old 04-25-2006, 03:42 PM Thread Starter
spearhunter
1975 CJ5
This is why Jeepers rock. Thanks, man!
1975 Wagoneer Ignition System Prestolite omanalansanjr Jeep CJ Forum 5 03-11-2009 11:47 PM
Wiring an ignition kill switch... Which wire do I tap/cut in to? jatepper Jeep CJ Forum 12 11-12-2008 09:50 AM
wiring a hidden kill switch on the ignition LostINohiO Jeep CJ Forum 3 08-06-2008 01:38 PM
Ignition switch wiring zglad Jeep CJ Forum 0 10-19-2006 10:25 PM
ignition switch wiring outdoordad@comc Jeep CJ Forum 3 02-08-2006 09:57 AM
