Ignition Switch Test?? - JeepForum.com
post #1 of 6 Old 05-29-2011, 04:52 PM Thread Starter
balls172
1982 CJ7
Hey guys, I am sure you can help me. I have searched for the answer but nothing helped me. My Jeep is an 82 CJ7 manual tranny with 258 motor. No prior problems then on attempting to start the key kind of felt like it was grabbing/grinding and did not return. Replaced the key switch but still happening so I am thinking ignition switch, how should these things act if they are good. I have the column torn apart now just to freshen it up and everything else looks good. Thanks in advance, Shawn
82 CJ 7
balls172 is offline
post #2 of 6 Old 05-29-2011, 05:32 PM
james04si
james04si's Avatar
1977 CJ5
down at the bottom of the column under the dash where the actual ignition switch is if you remove the switch from the column there should be a tab that moves back and forth that moves the ignition switch to the desired off/run/start positions. I dont know the wire color coding for the actual switch. hopefully someone will come along that can provide that information.
james04si is offline
post #3 of 6 Old 05-29-2011, 05:47 PM Thread Starter
balls172
1982 CJ7
I have the switch out, and it does slide back and forth. Is there any kind of return action to it when the key is released from start?
82 CJ 7
balls172 is offline
post #4 of 6 Old 05-29-2011, 07:16 PM
carguy68ssrs
1977 CJ5
The switch itself has a spring inside it to return key back from start position. Take a skinny Philips screwdriver and put it in the slot that the rod on column goes in and move it from 1 position to another. It should clic from position to position untill you get to start position where it will just spring back. you will feel the spring.
carguy68ssrs is offline
post #5 of 6 Old 05-29-2011, 10:27 PM Thread Starter
balls172
1982 CJ7
Ok, I think it is definately the ignition switch. It is very rough/gritty when manually operating switch with a screwdriver, there are clicks but no return spring action. Thanks for the help, I will keep you updated.....
82 CJ 7
balls172 is offline
post #6 of 6 Old 05-31-2011, 06:33 PM Thread Starter
balls172
1982 CJ7
UPDATE~ Changed out the ignition switch and it starts, however now my gears are slipping in the key switch. How do you change those.....
82 CJ 7
balls172 is offline
Ignition circuit key switch bypass for test run hfjeff Jeep CJ Forum 3 02-07-2012 02:54 PM
Ignition switch? toadking9 Jeep CJ Forum 9 08-25-2010 09:57 AM
ignition switch dirtdad Jeep CJ Forum 3 04-27-2009 08:56 PM
Ignition switch ragincajunATL Jeep CJ Forum 0 04-26-2008 02:29 PM
66 CJ5 ignition switch mattna4 Jeep CJ Forum 2 12-24-2005 05:13 PM
