Just pulled my old non- tilt steering column out at the intermediate shaft and replaced it with a rebuilt tilt version. Everything bolts up great but the ignition switch is different and the harness doesn't plug in as it should. Can anyone give provide a wire by wire explanation of what goes where or perhaps give me a lead on a harness plug that would allow me to fix the issue?
Anyone know what the green and light brown wires are for on the bottom of the pic? Its from an '86 with non-tilt. My other column which is an older tilt doesn't have these 2 wires. Thanks
I put a multimeter on both switches and was getting the same response so I plugged it in and everything fired up. After a few hiccups getting my horn to stop grounding out and stay on all the time, we're up running through Austin and sweating through our t-shirts at about 105 degrees. Thanks for the response.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
