Ignition Switch gears? - JeepForum.com
post #1 of 7 Old 07-03-2013, 06:57 PM Thread Starter
RoughIdle
1982 CJ8
Has anyone fixed stripped ignition switch gears?
I bought a CJ8 with a broken ignitions switch, they say they replaced the key switch itself and its the plastic gears that are broken but i can only find one gear and not the other anywhere. im not really sure how to fix it some toggle switches and hidden switches on the dash is getting old im not big on rigging things so they work i want it to be right if anyone has some info that could help i would really appreciate it thanks
RoughIdle is offline
post #2 of 7 Old 07-04-2013, 09:02 AM
keith460
Jeep. There's Only One
keith460's Avatar
NAPA has the Rack & Sector gears you are looking for.
1984 CJ-7 Renegade
keith460 is offline
post #3 of 7 Old 07-04-2013, 11:39 AM
texasdave
texasdave's Avatar
1980 CJ7
Don't just ask for Jeep. They are Saginaw parts used on about a jillion Chevrolets.
texasdave is offline
post #4 of 7 Old 07-04-2013, 04:52 PM Thread Starter
RoughIdle
1982 CJ8
oh wow awsome thanks guys
post #5 of 7 Old 07-04-2013, 11:37 PM
BagusJeep
1981 CJ7
The plastic sector gear can chip or wear teeth to the point where it slips on the rack. Then no start.
You will need to take the wheel off and strip the steering column to below the indicators to the point where you can push down into a small hole and press the locking bar into the side of the lock cylinder. It will then pop out from the side of the column and you can get in with some needle nose pliers to hook that sector gear that connects to the end of the lock cylinder. The new one just pushes in but make sure you get it all lined up right.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #6 of 7 Old 07-05-2013, 06:24 AM
keith460
keith460's Avatar
A word of caution if just replacing the sector and rack gear because you might be disappointed with the end results.
I replaced both gears and a key switch only to have the same problem occur with starting/not starting sometimes after the repairs. My original steering column had to be replaced due to the fact that the plastic housing where the rack gear moved in and out of was worn to a point where it would not keep the rack gear in alignment. The worn plastic column housing made the rack gear tilt some and would lose alignment with the sector gear and cause a no start situation.
I replaced the entire steering column with a rebuilt tilt wheel unit... problem solved.
1984 CJ-7 Renegade
keith460 is offline
post #7 of 7 Old 07-07-2013, 09:39 AM Thread Starter
RoughIdle
1982 CJ8
good to know i hope i dont have to replace the column those are very expensive new as you know
