Ignition Problems, No Spark, Need Help - JeepForum.com
post #1 of 8 Old 04-28-2014, 12:47 AM Thread Starter
pebo
1983 CJ7
This is my first post and im a little new to the car building thing so im having some serious trouble figuring out how to get it started. any ways, i have no spark, i tried doing the test when you pull the spark plug out and touch it to the engine block and look for a spark when cranking, but there is none. but when i do the same test on the coil (put spark plug in boot from coil to distributor) i get a orange spark. so i feel like it is something towards the distributor side or something i set up wrong. Almost all the electrical is new, new harness, new spark plugs, and i did the team rush upgrade, but did not get a performance ignition module, but is still new (there was no spark with the old cap and rotor). One thing i did notice though is that the number one spark wire slot on the distributor is at like 8 or 7 o'clock but i have seen a lot of diagrams and the number one is at 6 o'clock. I have also done nutter bypass
pebo is offline
post #2 of 8 Old 04-28-2014, 01:19 AM
Tyger78
I can't blow the picture up, but your vacuum advance nipple should pretty much be pointing at the center of your grill...... Is the distributor installed in the correct position?
I've done lost my mind...... mind.... mind.... mind..... mind..... what a silly word.
Tyger78 is offline
post #3 of 8 Old 04-28-2014, 01:25 AM
Tyger78
I understand that it doesn't matter how it's installed as long as it's wired up correctly. What I meant was:
If it was removed, installed in a different position, then the cap was installed in the same previous position...... then the firing order would be wrong. especially since the cap is marked with numbers.
Hope that helps at all. I apologize if I'm just making it worse =)
Tyger78 is offline
post #4 of 8 Old 04-28-2014, 04:42 AM
Mike Romain
At what point in all the wiring, etc. Did you lose spark? Was it dead before you started or?
Mike
Mike Romain is offline
post #5 of 8 Old 04-28-2014, 05:07 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Bring the engine up to TDC on #1 compression stroke
Remove cap and insure the rotor is under the #1 tower. Rotate distributor or move the wires if you need to to get it aligned.
Insure the rotor isn't damaged (tip burned off, center tang gone, etc). Replace if necessary
Insure the cap isn't damaged (towers intact, no corrosion, etc). replace if necessary
Inspect and test all spark plug wires. replace if necessary.
Re adjust the timing if you disturbed the distributor.
I'm betting the problem is with the cap/rotor.
jeepdaddy2000 is offline
post #6 of 8 Old 04-28-2014, 12:32 PM Thread Starter
pebo
1983 CJ7
Sorry to ask, but how to i find TDC, preferably without and expensive tools?
pebo is offline
post #7 of 8 Old 04-28-2014, 02:19 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Matt1981CJ7 is online now
post #8 of 8 Old 04-28-2014, 08:41 PM Thread Starter
pebo
1983 CJ7
Thanks guys, ill try this stuff out and see what happens.
pebo is offline
ignition
