Ignition problems no spark - JeepForum.com
post #1 of 3 Old 08-18-2012, 06:20 PM Thread Starter
tjd50317
Driving and 84 cj7 died. Towed home and no spark. The ignition lps fuse blown. Jeep wont start. About a year ago jeep would not start checked fuse box and ignition lps fuse blown (15A) changed and jeep started. What all does this fuse run? Is this the ignition fuse i keep reading about in trouble shooting threads? Looked under dash dont see any shorts can anything else cause fuse to blow? Are there any other fuses i should check? Thanks Tom
tjd50317 is offline
post #2 of 3 Old 08-26-2012, 07:26 PM Thread Starter
tjd50317
by-passed computer, dist. to ign module, redid vac lines and timing. runs like a top. just left out ign lps fuse did not see a need for it. had to replace alt. today because volt. reg. went bad over charging. Thanks Tom
tjd50317 is offline
post #3 of 3 Old 08-27-2012, 03:25 AM
RWise
1981 CJ5
The fuse is to keep the wires from shorting and catching on fire, good luck!
RWise is offline
1980 CJ7 Ignition NO Spark Electrican Jeep CJ Forum 28 09-17-2014 09:32 AM
'78 304 Ignition Help - No Spark _Kyle_ Jeep CJ Forum 8 12-21-2009 07:07 AM
CJ7 no spark - need help troubleshooting aftermarket ignition SJBrit Jeep CJ Forum 18 09-25-2009 03:10 PM
ignition problems / "one spark of death" texashighridin Jeep CJ Forum 8 03-20-2009 03:45 PM
prestolite ignition? Help needed... no spark. soundtech Jeep CJ Forum 8 11-05-2008 10:55 AM
