ignition problems - JeepForum.com
post #1 of 6 Old 03-20-2010, 10:03 PM Thread Starter
chank
1983 CJ7
ignition problems
i have an 83 cj7 laredo with a tilt steering wheel. i can only get it to start with the steering wheel all the way down and pushing down on it. guessing the switch or the key lock or both...any ideas?
chank is offline
post #2 of 6 Old 03-20-2010, 10:08 PM
halpeters
1978 CJ7
Most likely the switch is "out of adjustment"... It is located down the steering column. When you turn the key, it pushes a shaft that slides the switch. The switch is held in place by 2 screws, and the position of the switch can be adjusted to match the correct position of the key.
1978 CJ-7
halpeters is offline
post #3 of 6 Old 03-20-2010, 10:10 PM Thread Starter
chank
1983 CJ7
ok,,dont sound to bad. thanx a bunch
chank is offline
post #4 of 6 Old 03-20-2010, 10:12 PM Thread Starter
chank
1983 CJ7
one other thing. sometimes i get nothing and others i can here the starter spin but not engage...could that also be the reason for that?
chank is offline
post #5 of 6 Old 03-21-2010, 08:24 AM
Mike Romain
Yes and no.
The no start can be from it, but the spinning is more likely a dirty connection not allowing enough power to get to the starter to kick it out into the flywheel.
There are wear ports on the keyswitch linkage and I have seen repair kits for that slop. The steering column is a Saginaw column, the same as lots of GM's use.
Mike
Mike Romain is offline
post #6 of 6 Old 03-21-2010, 09:34 AM
jfwireless
1976 CJ7
Get your voltmeter out and see if you are getting +12 volts to the starter relay(soenoid) coil when you turn the keyswitch to start position. if not most likely the switch on the column.
Like Mike says, if the starter turns but does not engage you have a different problem.
Jim
jfwireless is offline
Ignition problems- Will not do anything-HELP PLEASE pwscj7 Jeep CJ Forum 71 03-14-2010 07:50 AM
Having ignition problems wbramble Jeep CJ Forum 2 12-13-2009 07:51 AM
Ignition Problems...???? xcopy Jeep CJ Forum 2 12-21-2004 05:29 PM
Ignition problems - HELP!!! mckinleyn3 Jeep CJ Forum 9 05-21-2004 05:58 PM
ignition problems 89' cj-7 mudmud Jeep CJ Forum 4 03-08-2003 10:11 AM
