Ignition Problems - JeepForum.com
post #1 of 6 Old 12-31-2010, 04:36 PM Thread Starter
scor572
Ignition Problems
Hey everyone...I'm stumped and could use some advice. Have an 84 CJ7 258/4spd that won't start. It turns over but will not fire. When I turn the key to the 'off' position, it fires (one time) like it is going to start. Here are the parts I have replaced: Plugs, wires, coil, distributor pickup assembly, cap, rotor, ignition switch, battery, and ignition control module. All voltage readings/resistance reading seem to be what they should be according to the Haynes repair manual, it's getting gas, but I'm not an expert. PLEASE HELP...beyond frustrated.
scor572 is offline
post #2 of 6 Old 12-31-2010, 08:23 PM
248107
Guest
1983 CJ7
did you replace the ignition switch on the column where all the wires plug in or the key switch that moves the ignition switch?
248107 is offline
post #3 of 6 Old 12-31-2010, 11:03 PM Thread Starter
scor572
Replaced the ignition switch on the column today...they key switch is a couple of years old.
scor572 is offline
post #4 of 6 Old 01-01-2011, 03:12 AM
raperfam
1977 CJ7
selonoid? maybe
raperfam is offline
post #5 of 6 Old 01-01-2011, 06:41 AM
BioTex
1979 CJ7
Did it just start this on it's own, or did you change the small wires at the solenoid?
Sounds like the run circuit is switched with the start circuit.
Are you getting voltage at the coil?
Did you check for spark at the plugs while cranking?
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #6 of 6 Old 01-03-2011, 02:29 PM Thread Starter
scor572
Nutter Bypass and voila...started immediately. Road test tomorrow.
scor572 is offline
ignition problems chank Jeep CJ Forum 5 03-21-2010 09:34 AM
Ignition problems- Will not do anything-HELP PLEASE pwscj7 Jeep CJ Forum 71 03-14-2010 07:50 AM
Ignition problems Schne Jeep CJ Forum 22 02-23-2010 07:57 AM
Having ignition problems wbramble Jeep CJ Forum 2 12-13-2009 07:51 AM
Ignition Problems...???? xcopy Jeep CJ Forum 2 12-21-2004 05:29 PM
