Ignition module with Painless wiring install. - JeepForum.com
post #1 of 8 Old 02-27-2014, 12:43 PM Thread Starter
lemmons1
Hello!
This is my 1st post to the jeepforum.com, and I have been reading these threads for the last 4 months since I bought my CJ-7. So thank you in advance, many have helped me get through some questions.
I am at the point of wiring my ignition in my '84 CJ-7, and I have come across something I am confused about. Every forum, thread, etc that I have read mentions using the purple/ violet wire coming out of the ignition module and twisting it to the orange wire, which they both go to the distributor. I pulled the entire old wiring harness and emissions ECM out and have it for reference if needed. I cut the wires going from the distributor to the ECM with plans on running them to the ignition module. I have upgraded to a TFI coil and already have in place the adapter, cap and rotor for the Team Rush upgrade.
This is my question/concern. There is a 4 wire connector coming from the ignition module that has the orange, purple, green and black wires. My OEM wiring harness with the 4 wire female connection only has 3 wires coming from it. - The purple wire does not come out of that connection. It ran before I did the wiring harness swap, so what wires do I use at this point? Do I buy another 4 pin connector and run the purple/orange wires to the dist or what? Please note, there is not even a terminal in the OEM connector for the purple male connector to plug in to.
Any and all help/ advice/ wisdom and knowledge is GREATLY APPRECIATED.
Thank you.
lemmons1 is offline
post #2 of 8 Old 02-27-2014, 12:52 PM
John Strenk
John Strenk's Avatar
1976 CJ5
You have to extend the purple wire to the ICM.
Remember to twist the orange and purple wire around each other to cancel noise pickup.
This is what you had
The distributor pickup signal ran to the computer and was processed there. All the computer sent out was the modified pulse to the ICM. That was all it needed to fire the coil.
You need to add some wires now directly to the ECM like this:
I grabbed an old harness from an earlier jeep to make the change.
You can probably find a 4 wire connector on any old Ford truck that uses the DuraSpark system. I'm not sure if you can just buy the plug or not.
AutoZone is mighty proud of their harness for this:
http://www.autozone.com/autozone/acc...er=841834_0_0_
John Strenk is offline
post #3 of 8 Old 02-27-2014, 01:11 PM Thread Starter
lemmons1
GREAT! Thank you sir. I can buy the 4 pin connector from O'Reilly; Dorman makes one. I do have another question though. Do I need to install the ancient ballast resistor shown in the wiring kit pictured in your reply? I have the old harness like I mentioned and I have read where there is a tracer wire (mine was red with green tracer) that could have been a resistance type of wire. There is not much resistance in it though, only 1.5 ohms. Is there an alternative to the ballast resistor or do I need to install it at all?
Thank you again!
lemmons1 is offline
post #4 of 8 Old 02-27-2014, 01:23 PM
Mike Romain
You need the ballast wire in for lowered voltage when in run.
Mike
Mike Romain is offline
post #5 of 8 Old 02-27-2014, 01:53 PM Thread Starter
lemmons1
My original wiring harness did not have that installed on it, so I was wondering. Thank you, I appreciate it.
lemmons1 is offline
post #6 of 8 Old 02-27-2014, 06:34 PM
John Strenk
1976 CJ5
Originally Posted by lemmons1
GREAT! Thank you sir. I can buy the 4 pin connector from O'Reilly; Dorman makes one. I do have another question though. Do I need to install the ancient ballast resistor shown in the wiring kit pictured in your reply? I have the old harness like I mentioned and I have read where there is a tracer wire (mine was red with green tracer) that could have been a resistance type of wire. There is not much resistance in it though, only 1.5 ohms. Is there an alternative to the ballast resistor or do I need to install it at all? Thank you again!
1.5 ohms is all you need. The wire running from the firewall to the ignition coil is the resistance wire that would take the place of the ballast resistor.
You don't need an additional ballast resistor. Sent from my iPhone using JeepForum
Your original wiring harness should have this resistance wire already in place.
post #7 of 8 Old 02-28-2014, 04:50 AM
Mike Romain
The original harness has a fat red/orange wire coming from the firewall area at a crimp connector that feeds the power in run. This is the ballast wire and this is one of the 'custom ignition' parts that doesn't come with the painless harness. My centech harness came with a ceramic ballast resistor to replace this.
Mike
post #8 of 8 Old 02-28-2014, 08:05 AM
John Strenk
1976 CJ5
Here is the splice Mike is talking about with the resistance wire:
If there is ducktape on the splice then you know it's original...
ignition , module , painless , team rush
