Ignition module and manifold ?? - Page 2 - JeepForum.com
post #16 of 17 Old 07-29-2011, 09:32 PM Thread Starter
Txjason1
1976 CJ5
Ok jeephammer,
Wired it exactly as the diagram you showed me is. It didn't work. No spark at all. Then my buddy tied the red and white from the ign box to the positive post of the battery and she started right up. No ballast, and only attached to one wire off the switch. Any ideas? This gonna have negative effects on the coil or distributor ? It only needs to last a couple weeks till I get the HEI unit in. What ya think, this had a v8 in it and is just now getting this 258. I am baffled, I bet you will be too
Thanks in advance.
Jason
76 CJ5
77 CJ7
98 Grand Cherokee
We are a import family!
Txjason1 is offline
post #17 of 17 Old 07-29-2011, 11:09 PM
JeepHammer
Running On Empty...
1973 CJ5
[quote=Txjason1;11939160]Ok jeephammer,
Then my buddy tied the red and white from the ign box to the positive post of the battery and she started right up.[quote]
Sound like a bad ignition fuse, bad factory tach, bad bulkhead connector through the fire wall.
Sounds like no power getting to the module when the key switch is in the 'Run' position.
Resistor goes to the line feeding the ignition coil, and without a resistor, the module won't last long if it's a DuraSpark type you are using. (Sounds like you are with 'Red & White' wires comment)
Coil or distributor, no,
Ignition module, Yes. They don't last long without a 1.35 Ohm or larger value resistor at the coil...
Thanks in advance.
Jason
I would say you have an interruption somewhere feeding the coil/module from the key switch.
One thing I forgot to mention is, but it's on the diagram,
When you swtich from Prestolite to Motorcraft ignition modules,
You need to add the 'Red' wire between the 'I' terminal at the starter relay and the ignition coil positive.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
ignition module climberman Jeep CJ Forum 6 05-07-2010 07:22 AM
Ignition Module # 4 yon Jeep CJ Forum 15 02-27-2010 05:35 AM
Ignition Module? boomvader Jeep CJ Forum 4 01-16-2010 11:03 AM
CJ5 Ignition Module cmcstotts Jeep CJ Forum 7 07-03-2009 09:40 AM
HEI Done! What About Ignition Module Jack-Jack Jeep CJ Forum 1 09-24-2005 10:42 PM
