Ignition Module # 4 - Page 2 - JeepForum.com
post #16 of 16 Old 02-27-2010, 05:35 AM
Mike Romain
Originally Posted by yon View Post
Well I built my module and pluged it in and nothing. It would crank but not start so I checked a little father and found that the female end of the 4 wire connector does not have a violet wire. So I guess I need to run one to the distributer, can I just tee tap into the wire and if so wont it also go to the main computer.
Both the orange and purple wires are controlled by the computer. That is what my above comment was about, the computer is still trying to run things.
To take the computer out of your misery you have to do what is called the 'nutter' bypass named after the first gent to publish it. This is not Ca legal at all, but the engine can still be tuned to pass emissions..
Mike
Mike Romain is offline
Ignition Module? boomvader Jeep CJ Forum 4 01-16-2010 11:03 AM
Ignition Module likeshills08 Jeep CJ Forum 23 02-21-2008 09:24 AM
New Ignition Module Maybe ???? Jimthejeepman1 Jeep CJ Forum 3 10-11-2007 05:00 AM
Ignition module nottooslow Jeep CJ Forum 4 10-03-2007 12:57 PM
76 CJ5 Ignition module ?? BamaJeeper Jeep CJ Forum 4 06-04-2003 03:58 AM
