Ignition Module - JeepForum.com
post #1 of 6 Old 05-18-2003, 06:50 PM Thread Starter
TG CJ7
Ignition Module
We've been having trouble starting my brothers stock '84 for about a year now. In fact it sat all winter because he didnt have time to work on it. Now that its getting warm he wants to drive it. Heres the problem.......
We are getting no spark. It seems like we are getting power to the module, but not out of it. We have tried 2 NEW ignition modules.
This is a quote from Hollywood which explained a lot last year.
if you are getting juice to the ignition module (via the blue wire), put the red/blue plug back together and unplug the other connector (orange, green, purple, and black wires). Again, with someone cranking the motor, test the orange wire COMING FROM the module. If there's no power here your module may be bad. If this is the case, the bypass will not work - but replacing the module ($25) will solve your problem anyway
The really strange thing is when I test the plug comming from the module (Brand New)
- the orange wire has no power.
- the black and green wire shows a very slight current (dim test light)
Sorry this as been so long. It seems like a very strange problem to me.
Thanks in advance
Tim
1979 CJ7 Renegade 304, 3spd, 2.5 BDS lift, Hedman headers.
Check it out
TG CJ7 is offline
post #2 of 6 Old 05-19-2003, 09:54 AM
mxg342
mxg342's Avatar
The plugs for the module went bad on my 84. We just cut them out and soldered the wires together and I never had any other problems.
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
post #3 of 6 Old 05-19-2003, 04:43 PM
fuzz401
1978 CJ7
i had mine break the one wire were it goes in to the plug or just take out the plug and crimp in conectors that you can take them apart and coat them with elec grease to keep them from coroding
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #4 of 6 Old 05-19-2003, 05:30 PM Thread Starter
TG CJ7
Thanks for your help
I dont think the plugs are corroded because the male ends are brand new and still look clean. I get power when I use the test light in the female end. I also loaded the female end with dielectric grease. Im going to clean the female end with a pipe cleaner anyway.
Right now im going to have the module checked at Autozone.
Is it possible that the module has to be grounded to the body?
Check it out
TG CJ7 is offline
post #5 of 6 Old 05-19-2003, 05:40 PM
MR.CJ-7
Yep the module has to be grounded. I found this out the hard way too. Mine grounds through the 4 bolts that hold it on the fenderwell. I ran an extra chassis ground to one of the bolts to help and no problems since.
Former CJ'er
MR.CJ-7 is offline
post #6 of 6 Old 05-20-2003, 01:55 AM
Sandman74
ditto- no probs since
Youth and talent is no replacement for age and treachery.
Sandman74 is offline
Ignition Module? boomvader Jeep CJ Forum 4 01-16-2010 12:03 PM
Ignition Module? jeepsarecool Jeep CJ Forum 10 10-19-2005 09:30 PM
HEI Done! What About Ignition Module Jack-Jack Jeep CJ Forum 1 09-24-2005 11:42 PM
hot ignition module?? T-$$ Jeep CJ Forum 2 08-14-2005 09:26 PM
76 CJ5 Ignition module ?? BamaJeeper Jeep CJ Forum 4 06-04-2003 04:58 AM
