ignition module - JeepForum.com
post #1 of 3 Old 05-04-2010, 08:42 AM Thread Starter
climberman
1979 CJ5
ignition module
we have a 1979 cj5 6 cylinder and we are ready to start it but I am still confused about the ignition module and whether I need it or not. the wiring harness that I have doesn't have the two plugs for the module but I got it from someone else so I don't know if it should or shouldn't so do I need a modularr and I have the wrong harness or do I have the right harness and not need the modular.
Thanks
Rocky
climberman is offline
post #2 of 3 Old 05-04-2010, 09:14 AM
TYoungone
1983 CJ7
The purpose of the module is to interrupt the coil to send the spark. I know my jeep (83 CJ 7, 258 engine) wouldn't run without it. The only way I can think you do not need it is if a different ignition set-up is installed. Good luck, I'm sure someone with some more knowlege will chime in.
TYoungone is offline
post #3 of 3 Old 05-04-2010, 11:51 AM Thread Starter
climberman
1979 CJ5
thanks for the help I think I have found the right harness and I am going to get now and see if it will work for our jeep
CJ5 Ignition Module cmcstotts Jeep CJ Forum 7 07-03-2009 10:40 AM
Ignition Module, MSD 6 crazycanuck81 Jeep CJ Forum 15 03-06-2009 11:09 PM
hot ignition module?? T-$$ Jeep CJ Forum 2 08-14-2005 09:26 PM
76 CJ5 Ignition module ?? BamaJeeper Jeep CJ Forum 4 06-04-2003 04:58 AM
Ignition Module TG CJ7 Jeep CJ Forum 5 05-20-2003 01:55 AM
