Ignition Key Cylinder Issue - JeepForum.com
post #1 of 3 Old 06-16-2013, 12:28 PM Thread Starter
magic_man1
1976 CJ5
I had rebuilt my 1976 CJ5 steering column roughly a 18 months ago and when it was back together, I found that the ignition key cylinder would not allow me to turn the key from the "OFF" position directly to the "START" position in a single twist. For some reason it will go to the "ON" position but then there is something stopping it from going to "START". But, if I turn it one click back towards "OFF" then proceed forward to "START", it will allow the cylinder to start the engine as it should.
This was not a problem 18 months ago, when I had a carburetor on the engine. Now that I have installed a TBI fuel injection kit that's computer is engaged at the "ON" position, it seems to be giving the computer fits when the power cuts out for that brief second while I have to turn the key backwards. This is because the power is cut-off as it is starting it's boot-up process.
Any ideas on what might be wrong? Is my "new" key cylinder bad? Is there a piece on the cylinder that just needs to be ground off, to allow it to rotate?
Thanks!
magic_man1 is offline
post #2 of 3 Old 06-16-2013, 02:46 PM
Skerr
Sounds to me like you could have a problem with the rack binding when you turn the key. Unfortunately, you have to go back into the column for that, but it sounds like you're going to have to anyway. Check the rack/sector component. Good luck.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3 of 3 Old 06-16-2013, 03:38 PM
Spieg8
1984 CJ8
You may have a couple of problems.
Key Switch - I can't think of anything that would prevent the key from going between the ON and START position other than a defective key/switch. Unless maybe an automatic may have some sort of neutral safety block (all my vehicles are manual floor shift so never had to deal with that before)?
Actuator/Rack - Even if you have to jiggle the key a little in the ON position, it shouldn't cut power unless there is something out of whack in the actuator mechanism (assuming you're not turning the key all the way back to OFF).
Spieg8 is offline
column , cylinder , ignition , key , steering
