Ignition Issues 1976 CJ7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Ignition Issues 1976 CJ7
50" LED CREE Light Bar Pair With Wiring KitIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineTeraflex JK LCG PRE-RUNNER KIT! ULTIMATE OFF ROAD PERFORMA
Unread 05-29-2014, 05:29 AM   #1
JBrad
1976 CJ7
Hey, new here to the forums. I've been working on getting my 1976 CJ7 back in shape. We've put in a new distributor, ignition coil, battery, starter solenoid, had the starter tested and it's looking fine as well, we've also gotten a new ignition control module in it. Now the problem we're having as that when you turn the key the engine does nothing. I'm not certain if it's a wiring issue as we've hooked everything up the way it was prior, or if it needs a new ignition switch as I haven't replaced that part yet. Any thoughts out there or any wiring diagrams so I can double check what we've got working under the hood? Thanks!
JBrad is offline   Reply With Quote Quick reply to this message
Unread 05-29-2014, 05:55 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
I would be checking the fender solenoid out. It must be grounded and if it has a tab on it for a wire, that must be grounded or go to the automatic tranny safety.
The small side posts are important. One is marked S and the other I. The blue wire from the key switch goes to the S post. The wire on the I post goes to the coil.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
