Ignition coil problems again - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Ignition coil problems again
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 01-25-2012, 08:31 PM   #1
PangaMan
1980 CJ5
What would make the ignition coil get so hot it cuts the jeep off?? It takes about 30 minutes of driving around to get hot and cut off. Once it cools it will sart back up and will run till it cuts off again.
PangaMan is offline   Reply With Quote
Unread 01-25-2012, 08:45 PM   #2
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Just replace it, if it's getting hot and cutting out, it will SOON leave you dead in the water. Not positive of all the internal workings, but I do know it will die completely.
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline   Reply With Quote
Unread 01-25-2012, 08:51 PM   #3
BagusJeep
1981 CJ7
Heat is a natural by product of that electrical field growing and falling and all coils will heat up.
However when it has reached the end of its useful life the heat will cause the internal bits to move around, which will show up as an open circuit. When it cools down it all makes contact again.
Time for a new coil. there are several options out there and Jeephammer has posted some junkyard alternates that will perform a lot better than the old one ever did.
BagusJeep lives in Bali, the Land of Temples.
With a Jeep every prayer counts.
BAGUSJEEP HAS GONE TO THE DARK SIDE OF GUCCI KIT - WEBER 38DGMS NOW NESTLES WITHIN
BagusJeep is offline   Reply With Quote
Unread 01-25-2012, 09:12 PM   #4
PangaMan
1980 CJ5
It was just replaced last week. With a new accell coil
Unread 01-25-2012, 09:17 PM   #5
BagusJeep
1981 CJ7
In which case what voltage do you have at the connections and what was the replacement coil designed for? CJs run on 6-7V at the coil in 'run" IF the ballast resistor is in place. If someone took it out the coil would overheat if designed to be part of a ballasted ignition.
The test procedure with a test light is to connect between the disconnected +ve wire and the -ve on the battery. A bright light should appear in 'start" and a much dimmer light in "Run".
Unread 01-26-2012, 06:51 AM   #6
PangaMan
1980 CJ5
Ok, on the + side of the coil I have 14v on the - side I have 9.6-10 volts.
Unread 01-26-2012, 07:26 AM   #7
waterdowg
Why did you replace the other one? Did it have the same symtoms? How do you have it mounted?
waterdowg is online now   Reply With Quote
Unread 01-26-2012, 07:52 AM   #8
PangaMan
1980 CJ5
the last one blew the post out of the top and shot oil everywhere. Left the key in the run position...
Ive only had the jeep since the end of January so im slowly learning all the wiring demons it has!
My question is I do not see a Balast resistor anywhere and the voltage confirms there is not one while it is running. What OHM resistor should I use and what should the voltage drop be while the engine is running. + side voltage and - side voltage?
thanks
Unread 01-26-2012, 08:00 AM   #9
waterdowg
Hmm I wonder if the ICM went bad as well since you left the key one. I know th ICM cam melt if the key is left on. So perhaps that is shorting and causing your problem. I really don't know for sure. Perhaps someone that knows more on ignitions will chime in.
Unread 01-26-2012, 08:45 AM   #10
PangaMan
1980 CJ5
Replaced that also...
Unread 01-26-2012, 08:47 AM   #11
JeepHammer
Running On Empty...
1973 CJ5
Burning coils up is usually a faulty engine 'Ground' connection.
To answer some questions,
1. The 'Ignition Resistor' in your vehicle is a 'Resistor Wire' in the harness.
The power wire for the ignition comes through the fire wall, then hits a 'Splice',
That splice splits the power in three directions,
First to the module, full battery voltage.
Second is a smaller wire to the alternator 'Excite' circuit which will have a 10 to 15 Ohm resistor wire in that line to the Excite terminal on the alternator.
The third wire out of that splice will be a 'Resistor Wire' to the ignition coil positive.
2. A cooked module will shorten the 'Dwell Time' to the point of overheating the ignition coil.
I'm sure you don't have a Dwell Meter to check the module, but a dwell meter is a way to check the ignition timing.
3. Insufficient 'Ground' to the engine block/spark plugs will cook a coil pretty quickly.
Since the coil can't discharge properly at the plugs, it winds up discharging internally.
'Super-Duper' coils are even more susceptible since they build higher voltage levels, and voltage is what breaks down internal insulation, and the makers of the 'Super Duper' coils sacrifice internal insulation for more windings to produce that extra voltage...
4. You can't test for 'Voltage' without loading the resistor in the supply line to the coil.
If you hook a small light bulb up in the circuit, then test for voltage with a load on the line, then you can get an accurate voltage drop across the resistor.
You would be better off turning the ignition switch off, setting your multi-meter to 'Ohms', unplugging the two wire connector at the alternator,
Testing the 'Harness' side of the module 'Red' wire and the unplugged coil 'Red' wire.
This will give your multi-meter a direct path through the resistor wire and will give you a direct reading of the ignition resistor.
Should read 1.35 Ohms or greater.
5. You might also do an Ohm (resistance) check between the primary (small) terminals on the coil.
I'm sure you will find your 'Super-Duper' coil is NOT making the proper resistance to work with your module.
JeepHammer is offline   Reply With Quote
Unread 05-27-2013, 10:01 PM   #12
rhfootball
1977 CJ5
Been having the same problems with my Jeep. Trying to get engine to start up, but keep having to break periodically due to the heated coil.
rhfootball is offline   Reply With Quote
Unread 05-27-2013, 10:07 PM   #13
LumpyGrits
Key word here--------GROUND
Engine to frame to body to battery
Confirm with a volt/ohm meter.
Use heavy stranded wire that will carry the amps when needed.
LG
LumpyGrits is offline   Reply With Quote
Unread 05-27-2013, 10:19 PM   #14
BagusJeep
1981 CJ7
Maybe, maybe not. If you look back at Pangaman it was unlikely he had the ballast resistor in line and had damaged the ignition module and coil in the process.
First check should be on whether the coil is wired up properly with a ballast resistor.
If the coil is toast it will stop working when hot. Time for a new one but also an electrical check over the whole system.
