Ignition Bypass Wire Help - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Ignition Bypass Wire Help
Attention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSBds fox ipf 2.0 racing series shocks now available at rockFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 03-19-2010, 08:58 PM   #1
mjeckell
1979 CJ7
I am a little confused. I have a 79 cj7 304. I purchased a painless wiring harness and I am trying to wire the engine compartment. What confuses me is the brown resistor bypass wire. There is a coil + wire labeled 781 brown. There is also a brown wire same size that is bundled with the starter solenoid labeled "I" term. It says that this wire is to be attached to the "I" post of the starter solenoid. I did a continuity test on both of the ends of the wires and it came out positive. It went from a 1 to a 0 on my multimeter. So I am assuming that this is the same wire. So if the "I" term brown wire goes to the "I" post then where do I put the other end of that wire I believe is wired 781 brown coil + ?????
mjeckell is offline   Reply With Quote
Unread 03-20-2010, 05:52 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Your coil has two power feeds. One from the I terminal that sends power when the starter is turning, and the other from the key switch and resistor wire when the engine is running. This way the coil sees 12 volts when starting and 10 volts when running.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote
Unread 03-20-2010, 08:26 AM   #3
mjeckell
1979 CJ7
So my harness came all braided so I can not see all the wires and the connections that PAINLESS made. I think the brown wire marked I TERM that is bundled with the starter solenoid is the same wire that is also marked 781 COIL +. This wire travels all the way from the I TERM location back to the area close to the fuse block and then pops out with 4 wires
720 RED/White COIL +
782 GREEN COIL -
723 PURPLE TACH (will not use)
781 BROWN COIL +
This is what it says about the 720 and 781 wire in step 5
The #720 red/white wire marked “coil +”attaches to one side of the ballast resister and the remaining
length of wire attaches to the remaining terminal and goes to the “ + “ side of the ignition coil on
Motorcraft, Prestolite and standard point style ignition systems. On GM HEI ignition systems the
red/white wire attaches to the “BAT” terminal at the distributor. The Brn #781 will be used only
when a Ballast Resistor is being used. It will be installed to the starter relay on the “I” post and
goes to the coil “+” side of the coil. This is a Ballast Bypass wire to be used only when a Ballast
In the duraspark ignition diagram it shows that this brown wire is spliced into the white wire coming from the 2 connector of the ignition module.
B. The ignition module group of wires
Motorcraft (Refer to illustration “E”)
1. The #720 red/white wire attaches to the red wire in the 2–way connector of the module.
2. The #719lt.blu wire attaches to the white wire in the 2-way connector of the module.
3. The #782 green wire attaches to the green wire in the 4-way connector of the module.
Without tearing into the loom, do you think that is the reason they sent the brown wire all the way back towards the fuse area is to splice into the 719 Lt.Blu and then I route that back directly to the COIL on the + side? There is enough wire for this.
Could I do a continuity test between the I term brown wire or the 781 brown COIL + and the Lt. blu that connects to the white wire from the ignition module. That would tell me if these are spliced right?
Unread 03-20-2010, 08:40 AM   #4
Mike Romain
No need. The blu wire has continuity to the blue wire on the S terminal of the solenoid so it gets power to the ignition module when the key is in start. This blue wire also is a different timing circuit, retarded for easy starts.
The white wire gets it's power when the key is in run and put the ignition module in normal run mode.
The brown wire just goes from the I terminal to the coil power 'after' the ballast resistor between it, the resistor and the coil power plug so the coil gets full voltage when starting. The stock one joins the coil power feed at a crimp about a foot away from the coil up in the loom and is pretty short.
I think you will need to figure how far back you need to feed the brown wire to get to that point. Maybe it can be pulled back a few feet and out the side of the loom?
Mike
Unread 03-20-2010, 08:58 AM   #5
mjeckell
1979 CJ7
I checked the brown wire from the I TERM and the brown wire labeled 781 COIL + and this is the same wire. If I am understanding correctly, this wire within the loom should not be connected to any other wire.
So would it be safe to say to start removing the brown 781 wire from the loom all the way back to I TERM. Then can I hook this directly to the + side of the coil with the 720 red/white wire?
Unread 03-20-2010, 09:03 AM   #6
Mike Romain
That is how it should work. The brown can go directly to the coil plus terminal if wanted rather than splicing it in.
Can you not just pull it out of the loom far enough to make the corner and go back out with the coil wire loom? This way it stays hidden and clean looking.
Mike
Unread 03-20-2010, 09:12 AM   #7
mjeckell
1979 CJ7
OK just for clarification. On the top of my coil it has two terminals. One says BAT and the other nothing. I am assuming BAT is the + side of the coil. Is this correct?
Unread 03-20-2010, 10:46 AM   #8
Mike Romain
I would guess that also. Do you not have the old harness to compare to?
Mike
Unread 03-20-2010, 07:23 PM   #9
mjeckell
1979 CJ7
Thanks for your help. I think I have it wired correctly. We will just have to wait and see once I fire it up
Unread 04-17-2014, 03:49 PM   #10
Brown80CJ5
Junior Member
Brown80CJ5's Avatar
1980 CJ5
I know this is an old thread, but what ever came about from sorting out the Brown #781 wire? I've run into the same problem and this thread came up in the search.
Brown80CJ5 is offline   Reply With Quote
Unread 04-18-2014, 05:07 AM   #11
Mike Romain
On a later CJ, the brown resistor wire from the alternator crimps to the coil's ballast wire so it is tied to ignition power before the ballast wire to the coil +.
On earlier CJ's this brown resistor wire hooks to the alternator idiot light.
Mike
Unread 04-21-2014, 11:45 AM   #12
Brown80CJ5
Junior Member
Brown80CJ5's Avatar
1980 CJ5
Alright thanks. I ended up taking apart part of the wire loom and found that the #781 brown wire just goes from one side of the engine bay to the other, and not into the firewall bulkhead. Just snipped off a piece long enough to go from the I-term on the solenoid to the "+" side of the coil.
Unread 04-21-2014, 04:44 PM   #13
John Strenk
John Strenk's Avatar
1976 CJ5
Was it connected to anything?
I'm just thinking that by connecting it to the (+) side of the coil, the regulator is going to see a lot of spiking every time the plug fires plus it's on the point of the ignition system were the voltage is only around 9 volts and with the sense wire hooked up there, the regulator might boost the alternator output to high trying to compensate. This will cook the battery and shorten the life of any electrical part.
I would check the voltage coming out of the alternator just to be sure it's operating at the correct voltage.
I'm pretty sure Mike said to hook it up BEFORE the ballast resistor.
John Strenk is offline   Reply With Quote
Unread Yesterday, 04:18 PM   #14
Brown80CJ5
Junior Member
Brown80CJ5's Avatar
1980 CJ5
The wire goes directly from the I-term on the starter solenoid to the + side of the coil. In all the diagrams I have seen it it says to hook it up after the ballast resistor and not before as it acts as a resistor bypass for starting the vehicle. I think I am saying all of that correctly. I know that it has nothing to do with the brown wire coming from the alternator.
Unread Yesterday, 04:47 PM   #15
Mike Romain
The wire from the I terminal is only used when the key is in the start position. It then powers the coil.
When the key is in run, the coil gets its power through the ballast resister wire from the other direction. The resistor wire hooks to the one from the I terminal about a foot from the coil and runs across the firewall toward the brake booster where it crimps to the brown resistor wire that feeds the alternator sense circuit.
This makes the alternator sense wire see full power from the fuse before it gets lowered via the ballast wire to the coil.
As John says, getting this low voltage power at the coil will make the alternator work way too hard while boiling your battery dry trying to get to 12 volts on a 9 volt circuit.
Mike
