Ign module - JeepForum.com
post #1 of 21 Old 09-20-2004, 09:34 PM Thread Starter
CJ-5
Ign module
This may sound like a really stupid Queation, but anyway......
Is there any reason I can't bypass my ignition module and run switched power to the pos lead on the coil, then directly to the P/U coil in the distributor, from the neg lead on the ign coil ???
Just like it was done in the points days.
What does that magic box do anyway ??
CJ-5 is offline
post #2 of 21 Old 09-21-2004, 07:42 AM
Geer_hed
Geer_hed's Avatar
I'm thinking no. Seems like too complex an operation. I had this conversation surrounding the Ign Mod over at off-road, and this guy sounds pretty competent.
http://bbs.off-road.com/ubbthreads/s...froadjeepshort
85 CJ7 / 258 / T176 / Dana 30/ AMC 20
Geer_hed is offline
post #3 of 21 Old 09-21-2004, 09:26 AM Thread Starter
CJ-5
Complex ??
What part sounds complex ??
CJ-5 is offline
post #4 of 21 Old 09-21-2004, 09:42 AM
Geer_hed
Geer_hed's Avatar
The part that's complex is the board on the inside of that Ign Mod that is lined with a series of resistors and switches that allows the ign mod to open and close at specific increments/voltages. The Ign Mod is not "ALWAYS ON" during vehicle operation, evidently, it fluctuates frequently, so I tend to shy from the idea of running constant voltage. I guess I'm just not gutsy enough to try to rig the ignition circuit the way you're talking about doing it.
Good luck... Hope it doesn't on you.
Geer_hed is offline
post #5 of 21 Old 09-21-2004, 03:46 PM Thread Starter
CJ-5
Worst case
worst case will be the p/u coil won't be able to handle all 12V constantly, and fry out. Maybe not right away, it might wait til I'm in the middle of a forest with no tools.....................you know the rest...............
CJ-5 is offline
post #6 of 21 Old 09-21-2004, 04:53 PM
jode
Far too simplistic an assumption IMHO…what about dwell, duration, and all that? Plus, I tend to think that if you ran all that current through your P/U coil, you would smoke it.
Hung like Einstein and smart as a horse...
90 YJ, 2.5L, 5-speed
jode is offline
post #7 of 21 Old 09-21-2004, 05:22 PM
Aphelion79
Aphelion79's Avatar
Well if you're talkinga bout the little box thats fixed on the inside of the passenger side wheel well in the engine compartment all it is, is a sucking coil... which when the alternator sends so much power to it, it completes the connection that allows your electronic choke to opperate... thats it...
PC boards... ?!
Thats how it is on my 4 Cyl anyway... question is do you have a 4 or a 6...
1982 CJ7
Iron Duke "Hurricane" 151 CID 2.5L 4-Cyl
T177 Tranny | Dana 300 T-Case
Dana 30 Front | AMC 20 Rear
Aphelion79 is offline
post #8 of 21 Old 09-21-2004, 07:16 PM
rcsutton
2010 JK Wrangler
Couple questions, I have 80 - 258, Are all these modules the same? Do they get pretty warm? Would a conversion to a 1 wire alternater have any effect on the module? How does the wire to the choke come into play? Would juice box affect the module? I will copy and past my problem from another thread, Thanks
Well here we go. Installed Weber carb. Ignition module went out. Coincidence? Installed a second one, ran for 5 min went out. Installed 3d one lasted about 3 days 100 miles? Any ideas? I can't imagine Weber in the mix, only thing there is Red wire to choke. The original was working until Weber was installed, then I got about 5 miles on rig before it went. ?????????????
Would any of these mods affect module?
Juice box
1 wire alternator
Weber carb choke wire?
2010 2 door JK Red Rubicon.
rcsutton is offline
post #9 of 21 Old 09-21-2004, 07:45 PM Thread Starter
CJ-5
Jode
Maybe I'm missing somthing, but isn't dwell and duration controlled by the weights and the vacuum pot ???
CJ-5 is offline
post #10 of 21 Old 09-21-2004, 10:09 PM
Jeep Daddy
Jeep Daddy's Avatar
Where is the condensor? Is that part of the ignition module?
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #11 of 21 Old 09-22-2004, 08:24 AM
Geer_hed
Geer_hed's Avatar
Ok.
The OEM Duraspark ignition system has a default, non-adjustable dwell. Duration , in this context with respect to the rotation of the rotor button, is synonymous with Dwell. In this case, Dwell never changes, regardless of advance or rpm. The distributor uses centrifugal and vacuum advance to accommodate spark advance. In the OEM setup, the EECU controls the coil spark command from the Pick-up Coil to the Ign Mod. The vacuum advance usually supplements the mechanical advance in keeping with the demand placed on the distributor by idle speed, vacuum, and rpm.
For the most part, the Ign Modules appear to be pretty much the same. Years 73 - 86 appear to call for the same part number, though the engine wiring setup clearly changed over those years.
I've not ripped one of these distributors to pieces, but usually the condensor is somewhere between the Ign Mod and Distributor. I can't say for sure that I've even seen one on my jeep. It's purpose is to soak up excess voltage in the ignition system to keep from frying the points. HEI systems definitely have a condensor. There is a watch-battery sized cylinder on the OEM Jeep Ign Module board integrated with the resistors, so maybe that's it. Yes there's a "PC Board" or rather a circuit board inside that box that makes sense of the input/ouput scheme on all those wires. If you've got a dead one and a torch, if makes for interesting busy work to rip in to one.
Geer_hed is offline
post #12 of 21 Old 09-22-2004, 01:28 PM Thread Starter
CJ-5
thx
Thx Gear hed, that's what I've been looking for.
Thanx also to all the responses of this thread. You have been most respectful of my lack of knowledge in this topic.
CJ-5 is offline
post #13 of 21 Old 09-22-2004, 03:02 PM
Geer_hed
Geer_hed's Avatar
Welcome...
Geer_hed is offline
post #14 of 21 Old 09-22-2004, 03:24 PM
Jeepbeeper
that resister is there to void excess voltage spikes upon start up and shut down and during aggressive acceleration spikes.
If you take it out you can burn up your moduel in time...
hope this helps
Keep on Jeep'n
Jeepbeeper is offline
post #15 of 21 Old 09-24-2004, 03:55 PM
jode
OK - been doing some thinking on this - Here's my thoughts, and make sure to sing out if I get something wrong here…
The pickup coil (in the distributor) - as a magnet passes through some coiled wires, it "induces" current. In other words, the magnetic field acts upon the electrons in the wires and starts them moving. So you have a VERY SMALL amperage electric current.
The ignition coil gets a (+) charge directly from the battery and it is regulated to 7or 8 volts or something by the resistor wire. A field develops in the coil and then remains constant UNTIL a path to (-) is opened up through the ignition module. This path to ground is momentarily opened and allows the field in the ignition coil to momentarily collapse (which sends a high voltage zap down to your spark plugs).
Assuming all of what I just said is correct, if you step back and look at the two systems, you see that the signal sent from the pickup coil is (+) and the signal that allows the ignition coil to fire is (-).
Therefore, running the pickup coil directly to the coil would not be the same as when you used a module and would not work.
jode is offline
HEI module question chadlow Jeep CJ Forum 3 01-04-2009 02:19 PM
Cj8 Module JEEPPARTSGUY Jeep CJ Forum 3 09-07-2006 09:21 AM
Ignition Module? jeepsarecool Jeep CJ Forum 10 10-19-2005 08:30 PM
HEI Done! What About Ignition Module Jack-Jack Jeep CJ Forum 1 09-24-2005 10:42 PM
Module PROBLEM ??? skeeter USA Jeep CJ Forum 11 06-23-2005 07:48 PM
