If you had 3-4 thousand for drivetrain in CJ5 - JeepForum.com
post #1 of 5 Old 09-20-2015, 01:10 PM Thread Starter
Wisconsinite
1981 CJ5
Here is the deal, I picked up a '81 CJ5 with the intent to rebuild it as a capable off road rig. Here is what I am working with:
4.2l 6 cylinder
SR4 four speed
300 transfer case
Dana 30 front
AMC 20 rear (shot)
Spring over with 36" tires.
I love the big tires and the stance it currently has and would like to keep it close in size, but maybe go a bit wider.
If you had 3-4 grand to build a reliable rig what would you do? I would like specifics if possible. Axles, tcase, tranny, springs?
I am capable of doing welding, cutting, fab, and most of the skills required. Not at the level of you folks, but I get by.
Thanks for your input.
Josh
Wisconsinite is offline
post #2 of 5 Old 09-20-2015, 03:39 PM
TIPPEDITOVER
In the Lab
TIPPEDITOVER's Avatar
1978 CJ5
Just do it like mine. Specifics can be found in my profile
"Societies that lose the cohesion needed for concerted, collective action collapse, either by failing to meet an external threat or from internal conflicts."
Shaun
1978 CJ5 - Rebuild in progress......
TIPPEDITOVER is offline
post #3 of 5 Old 09-20-2015, 07:57 PM
HAVO
1980 CJ7
reliable + 36" tires + wider = v8 + 1 ton axles.. dont reinvent the wheel, its more than proved already for a long time
the ONLY thing i keep of your setup is the transfer case (DANA 300 very good transfer)
HAVO is offline
post #4 of 5 Old 09-21-2015, 03:24 AM
gmakra
That depends on what you want the Joop to do?
You say capable off road you live in Wis so what conditions will you be driving in?
Sand, mud, rocks
gmakra is offline
post #5 of 5 Old 09-21-2015, 05:39 AM
sireland67
3-4 k to spend.
Lets assume the body is in decent shape and it runs and shifts good, with a good clutch.
Rebuild the dana 20, add a limited slip differential, one piece axles, and about 4.11 gears.
Re-gear the front to 4.11 but leave the differential open.
Go completely thru the drive train, replace all u-joints with heavy duty spicer blue caps.
Add a 8,000 winch, 2.5" lift and 33" tires.
Budget spent.
sireland67 is offline
