Idling problems (stock carb) - JeepForum.com
post #1 of 3 Old 03-10-2007, 07:58 AM Thread Starter
mmerlina
Image Glassworks, Inc.
mmerlina's Avatar
Hey everyone, I know I know I should change to the mc2100, but I just don't have the cash right now.. when I do, I will believe me.
But anyhow for now, the jeep stalls when I start slowing down, like if I have to take a corner or something.
There are 3 throttle screws and 2 idle screws, the idle screws I have turned out 3 full turns. I believe I read that somewhere.
As far as the throttle screws, I've been tinkering back and forth with them to try and find the problem, but it's just not happening. I do not know how to set them properly, does anyone have any information on how to do so?
Thank you!
Mike
1986 Jeep CJ7 (
Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work
mmerlina is offline
post #2 of 3 Old 03-10-2007, 11:20 AM
BLS33
Chief of the brain police
BLS33's Avatar
BLS33 is offline
post #3 of 3 Old 03-10-2007, 12:08 PM
backstrap
May not be the problem BUT, My stock 81CJ was doing the same thing. I brought it to a machanic who did a tune up, changed the distributor cap. jep still did it. I got to looking at it one day and just started pulling vacuum lines.(one at a time) On the back of the carb.(firewall side) there was a line I pulled,vacuum advance or something like that( line goes to distributor) when I pulled it Jeep idled perfect. no more stalls just smooth running. Has more power through all gears. Mechanic says if it runs good leave it plugged off. Let me know if this helps. Or if Im killing my Jeep.
Got Mud?
backstrap is offline
82 CJ7 258 Carb Problems? BucketRider Jeep CJ Forum 7 03-23-2009 03:47 AM
Carb stuck, Idling very fast hookntail Jeep CJ Forum 2 09-18-2008 08:14 AM
Carb Problems AMC Power Jeep CJ Forum 4 09-08-2007 01:23 PM
Idling Problems jrylb73 Jeep CJ Forum 3 04-01-2007 04:52 PM
Took My Carb Apart...Still Not Idling.. tmak504 Jeep CJ Forum 18 07-10-2006 10:26 PM
