Idle problems - JeepForum.com
post #1 of 3 Old 03-27-2013, 08:10 PM Thread Starter
samscj5
1973 CJ5
Idle problems
I have a 1973 CJ5 with a 304 V8 , 2 bbl motorcraft carb, and a 727 toqueflight trans. In park at high idle it stays running but when i put in in drive it will idle for a few seconds then starts idleing rough then wants to die. Carb is rebuilt, new wires and spark plugs. Any input would be appriciated. Is it possible that it could be the PCV valve? Im pretty sure i dont have any vacuum leaks.
samscj5 is offline
post #2 of 3 Old 03-27-2013, 08:20 PM
Trapshooter
Need to ask......how do you know you do not have any vacuum leaks.
Have you performed any recent maintenance on the engine?
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #3 of 3 Old 03-27-2013, 08:51 PM Thread Starter
samscj5
1973 CJ5
I only have two vacuum lines, from carb to the distributer and from PCV to carb. Both dont leak
samscj5 is offline
