Idle Issues - JeepForum.com
post #1 of 7 Old 07-23-2010, 12:43 PM Thread Starter
abrokjp
1978 CJ5
Idle Issues
Let me begin by saying I am not a mechanical genuis. What I know I learned here or from my CJ5 (usually the hard way).
I drove my Jeep for about an hour early this morning with no issues. A couple of hours later my daughter and I took it to town and it would completely die when coasting to a stop sign. It would start right back up every time, but I had to keep my foot on the gas when at a stop.
I figured the idle was out of adjustment so when I got back to the house I ran it and just screwed the idle screw in/out until it was running even. Took it for a test drive with no issues. Later I was noodling around under the hood and heard something that normally isn't there. I look at my fuel filter (clear) and there are bubbles coming up in the fuel that is present in the filter. Screwed the idle adjustment back out and it stopped.
I assume these bubbles can't be good, right? But if I have to have it turned up to get it to run, is there something else that could be causing my issues?
Thanks,
Matt
abrokjp is offline
post #2 of 7 Old 07-23-2010, 01:14 PM
honkytonkrollti
1980 CJ5
Please fill out your Jeep profile so we can see your Jeep's specifics ie what motor/carb you're running. This will help you get answers faster.
Respectfully,
Kevin
honkytonkrollti is offline
post #3 of 7 Old 07-23-2010, 02:03 PM Thread Starter
abrokjp
1978 CJ5
258 w/MC 2100.
abrokjp is offline
post #4 of 7 Old 07-24-2010, 08:13 AM Thread Starter
abrokjp
1978 CJ5
This is weird. It is like when you blow through a straw into water - steady line of bubbles in the filter. I have checked all of the soft fuel lines for cracks and all of the clamps. I couldn't see anything but I am going to replace all of them anyway.
Any other ideas?
Thanks,
Matt
abrokjp is offline
post #5 of 7 Old 07-27-2010, 08:35 AM
twmattox
Fuel pick-up filter (also called a fuel sock). If it is cracked it can cause this too...especially when the fuel level drops...
twmattox is offline
post #6 of 7 Old 07-27-2010, 11:20 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Sounds like vapor lock. It sounds like you may not have the correct fuel filter that has a third fitting on it to allow gas vapor to return back to the gas tank.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #7 of 7 Old 07-27-2010, 01:45 PM
tigercreek
I second this.
The filter with 1 inlet and two outlets really helps. Make sure the return outlet (offset) is on top.
No matter where you go, there you are.
tigercreek is online now
carb , carburator , dying , fuel filter , fuel pump , idle , stalling , vapor lock
IDLE Issues V8 304 AMC CJ-7 rkinks35 Jeep CJ Forum 9 04-10-2010 01:27 PM
charging issues at idle joes1982CJ Jeep CJ Forum 8 10-29-2009 09:40 AM
mc2100 idle issues starfire340 Jeep CJ Forum 4 04-13-2009 09:50 AM
Need help with carb issues. Won't idle cjflexin1985 Jeep CJ Forum 0 07-07-2008 09:39 PM
Idle issues obscurotron Jeep CJ Forum 0 08-05-2007 08:16 AM
