Idiots guide to a 1973 Junker CJ5 - Page 3 - JeepForum.com
post #31 of 71 Old 07-04-2013, 12:33 PM Thread Starter
Deeznutz73
1973 CJ5
Then I started with a rough sanding wheel on the dremel, then progressed up to a finer one, followed by hand sanding it with 400, then 600 grit paper.
IMG_20130624_202543_683.jpg   IMG_20130630_224253_451.jpg   IMG_20130630_224304_132.jpg
This shouldn't be too hard...........
Deeznutz73 is offline
post #32 of 71 Old 07-04-2013, 12:39 PM Thread Starter
Deeznutz73
1973 CJ5
I also soaked it in hot water and dawn dish soap for a few hours, then hit all the ports with a pipe cleaner to remove any metal bits.
I then mostly put it back together. Nothing is tightened down. I'm still waiting on screws for the butterfly plates.
I'm not going to cover the throttle body rebuild because it was too easy. If you can look at pictures, you can rebuild a throttle body!
And that's it for the throttle body. I would avoid a mirror shine, since I've heard that fuel can stick to it. I'm not 100% on that, especially since the throttle bore is half rough, half mirror finish.
post #33 of 71 Old 07-04-2013, 03:16 PM
chatham
the frame spacers are to prevent the boxed area of the front frame from collapsing when you install the rear front spring mount. I am surprised that you didn't get those with the kit.
my jeep is just a frame on axles with springs and brakes. trying to get the tires on it this weekend so I have a rolling chasis but I just found out I have the wrong ebrake cables for the rear brakes. ugggggggggggggg. welded in a mount for the proportioning valve today and mounted that. I am running front discs from 85 cj5 and power steering. mounting the steering box as we speak. will run fuel lines this weekend and mount fuel tank. should be ready to test fit the new body after that.
I purchase off ebay from tom's yj spring kit with 3.5" lift. I will add another 1" on boy mounts to that see how it looks. will be running 33" tire so it should sit nice.
chatham is offline
post #34 of 71 Old 07-04-2013, 03:40 PM Thread Starter
Deeznutz73
1973 CJ5
Hmmmm now I'm nervous. I'll have to look through the kit again. I know there isn't anything on the inventory list that says spacer. If you can see it on yours, you should snap me a pic.
post #35 of 71 Old 07-04-2013, 04:05 PM Thread Starter
Deeznutz73
1973 CJ5
Son of a . I scrambled to the installation directions and read over the parts you referenced and there it was, my impending doom. I'm going to pull out all the parts and double check for them, but I'm pretty sure I didn't see them. I'll take pics and label them for r unda and if you see something missing, let me know. I did notice they sent me the extended shock mounts, which I didn't think came with it?
post #36 of 71 Old 07-04-2013, 04:50 PM
r_unda
That would be great! Thank you!
My Jeep isn't getting older, it's getting newer part by part
2011 WK2 HEMI 4x4 Overland
2007 WK CRD 4x4 Limited GDE Tuned
1998 TJ SE
1973 CJ5 - YJ OME 2.5" lift, 33" tires
1951 Willys truck
r_unda is offline
post #37 of 71 Old 07-04-2013, 09:14 PM
fuzz401
1978 CJ7
you should have the model 44 flange axels in the back rear and so you know moser does make an axel for that rear 30% stronger then factory I had them make me 2 sets for mine
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #38 of 71 Old 07-05-2013, 02:25 PM Thread Starter
Deeznutz73
1973 CJ5
OK so here's the E brake pics. Let me know if you need anymore from a different or better angle. I started off with the one coming from my left rear wheel
IMG_20130705_125712_556.jpg   IMG_20130705_125730_589.jpg   IMG_20130705_125800_157.jpg   IMG_20130705_125750_026.jpg
post #39 of 71 Old 07-05-2013, 02:45 PM Thread Starter
Deeznutz73
1973 CJ5
And here is the RRO kit and pieces
Chatham are those the spacers you were referring to?
IMG_20130705_124256_565.jpg   IMG_20130705_124307_723.jpg   IMG_20130705_124326_630.jpg   IMG_20130705_124340_604.jpg   IMG_20130705_124351_219.jpg
post #40 of 71 Old 07-05-2013, 03:11 PM Thread Starter
Deeznutz73
1973 CJ5
And here is the RRO directions. They may be out of order since they aren't numbered and my dog got a hold of them. Luckily he only ate the first page of "thanks for spending all your money on our product, etc, etc, etc"
EDIT: I have been working on this recently, since I have had some time off and thought this was simple. If you have a straight jeep, this is a moderately easy kit. It, however, is not a bolt on. There are several holes to drill and you will need to cut your original spring hangers down. With the previously mentioned setup, I have found that I gained almost 5" from this lift. I now have a very steep drive shaft angle and short brake lines. RRO did not include the spacers that go in between the frame rails for support, which led to me waiting around for two weeks (kid was supposed to mail them off, but left on vacation instead). The quality of the product is nice, but there are gaps in the brackets/frame that I feel create a week point, should the frame twist. the shackles are also a narrow to wide style on the rear, but straight on the front. I THINK this creates a week stress point on the frame since the spring hangers are narrower than the 2.5" leaf. Any twisting will occur in that area.
Yup! Got her all mounted up. Gained 4 1/2" from it, which jacked everything up. My drive shaft angle went way steep, like 35 degrees. To counter this, I dropped my transfer case from 3/4" (PO installed) to home made 1 3/4" drop. This brought my angles down so I can now put shims in and put in a Dual CV drive shaft, which will come from a Ford explorer (another article for later). I also have to get new brake lines. Looking at removing a leaf and possible putting factory height boomerang shackles on.
7-5-2013 2;01;51 PM.JPG   7-5-2013 2;01;55 PM.JPG   7-5-2013 2;01;57 PM.JPG   7-5-2013 2;01;59 PM.JPG   7-5-2013 2;02;01 PM.JPG
post #41 of 71 Old 07-09-2013, 02:50 PM
r_unda
Thanks for the pics of the conversion kit! keep us updated!
1998 TJ SE
1951 Willys truck
r_unda is offline
post #42 of 71 Old 08-01-2013, 10:03 AM
tgbaldwin
1973 CJ5
wow, great thread, I've enjoyed every page. I have a 73 also but have a blown 304. I have aquired a very good running 258 from a 77 amc pacer. I'm having a hard time finding proper engine mount brackets, can't even find any pics so I know what to look for. would you have the time to post pics of yours? It would be greatly appreciated.
tgbaldwin is offline
post #43 of 71 Old 08-02-2013, 08:06 AM
scoutboater
1974 CJ5
Hey, nice thread! I've got a '74, so I feel your pain on having to figure out what works for us and what doesn't. I'll be following for sure, and I'll try to pitch in whenever I can.
scoutboater is offline
post #44 of 71 Old 08-07-2013, 03:11 PM Thread Starter
Deeznutz73
1973 CJ5
So haven't had much time to work on the heep lately, but I did do a little more tightening up of the harness and and laid it out to check wire lengths. I'm messing with the adapter plate issue right now and should have a better idea on that tomorrow.
Here's the pics of the motor mounts. Rock auto has the rubber mounts for like $6 each
IMG_20130807_135629_905.jpg   IMG_20130807_135647_639.jpg   IMG_20130807_135715_007.jpg   IMG_20130807_135744_430.jpg   IMG_20130807_135801_695.jpg
post #45 of 71 Old 08-28-2013, 08:39 PM
r_unda
Any update?
1998 TJ SE
1951 Willys truck
r_unda is offline
