Identifying Dana 44s - JeepForum.com
post #1 of 10 Old 02-26-2013, 10:24 PM Thread Starter
Jeepkid1995
1979 CJ7
Hey all,
Little break in my Chevy project, was wandering around a local junk yard and came across a late 60's International scout. Had a big block 360, I think it was, and pretty intact looking axles, which are, if I'm not mistaken, Dana 44's? I would love to pick up a set of these for my build, just need help identifying them. As for price, the employee I asked was not very clear, he either said 36 dollars an axle or 360 apiece. Is the latter a good price? Thanks for the feedback!
(Sorry I couldn't get very good pictures, Blackberry camera isn't the greatest. Also, couldn't get enough light to get a good picture of the rear pumpkin)
65906_344416415674767_357262362_n.jpg   557952_344416452341430_693132504_n.jpg   733754_344416489008093_1496688237_n.jpg
->'79 CJ7 (VIN Says it's a 5, wheelbase says otherwise), 6 inches of spring lift, awaiting an MC2100 on a teamrushed MSD'd 258
-->350 time. '95 block SBC, stroked to 383, dremeled heads and big 'ol intake, maybe a Holley 750 CFM, not sure yet
--->"Safety? Buy a Volvo. Never buy a CJ, or a Chrysler Jeep knock off, for safety, fuel mileage, reliability, handling, ride, comfort, aerodynamics, quietness, convience, stability, low maintenance cost, performance, or ease of use. The only reason to buy a CJ is because you are absolutely, incurably nuts." -OldTexas
Jeepkid1995 is offline
post #2 of 10 Old 02-27-2013, 01:00 AM
big_o_tom
1978 CJ7
Look just like my scout 44's.
big_o_tom is offline
post #3 of 10 Old 02-27-2013, 07:07 AM
BagusJeep
1981 CJ7
Here is a good guide to diff covers, but it will not tell you what lies beneath, rust, broken teeth etc
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 10 Old 02-27-2013, 11:32 AM
CSP
Are you sure of the year? Scouts didn't get a 44 in front until '74, but that is a front 44.
CSP is offline
post #5 of 10 Old 02-27-2013, 11:46 AM
CJ51973
CJ51973's Avatar
This will help decoding the BOM number.
/http://www.therangerstation.com/tech_library/Dana_BOM_numbers.html
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #6 of 10 Old 02-27-2013, 12:18 PM
foggybottombob
That is a scout front D44 identified by the 8 bolts on the spindles and the long dogleg steering arms.
foggybottombob is offline
post #7 of 10 Old 03-03-2013, 03:20 PM Thread Starter
Jeepkid1995
1979 CJ7
I am not entirely sure of the year, may be wrong, but I went back and identified the rear as a 44, too. So, off a scout, these are full width axles then, which require out-boarding of the springs? Because I confirmed the price. The yard has a set price for solid axles, 40 bucks plus a 15 dollar core charge. If these axles are a plug and play where my current wide track D30 and AMC 20 are, well, sold. But if they need the springs moved out, I might as well search for a D60 front and a 14 bold rear for the same price and amount of work.
So my question, are scout Dana 44s full width, and require outboarding leafs? Sorry if that's kinda tricky to tell without a definite year
post #8 of 10 Old 03-03-2013, 06:13 PM
CJ51973
CJ51973's Avatar
For the front it will be outboard. Rear you can move the perches. These are not as wide as a full sized truck.
CJ51973 is offline
post #9 of 10 Old 03-03-2013, 06:32 PM
BlueRubiconrich
Yes looks like someones swapped later axles into a early Scout.
The Rear Scout Dana 44 is easy get your pinion angle right and weld on new perches. The front you have to cut off the outer c's and turn them to get your caster. Your Jeep30 had 6 degrees of caster only 1980 Scouts had 2 dregees all other had 0 degrees. then outboard your springs set pinion angle and weld on new perch. Or do what I did and cut 3 5/8's off the longside and then cut a chromemolly shaft and repline it.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #10 of 10 Old 03-03-2013, 07:49 PM
CSP
It's not the overall width that determines if outboarding is necessary, it's the spring perch spacing. Scouts have wider spring perch spacing than a CJ, so yes, the front will have to be outboarded. As already said, you can relocate the spring perches on the rear axle.
CSP is offline
