Identify front bumper - JeepForum.com
post #1 of 9 Old 09-07-2013, 10:54 PM Thread Starter
Trendsetter75
2010 JK Wrangler
Could someone tell me what kind of front bumper setup this is and what is it used for? Do they still make this and would it fit an LJ?
2010 JKU (6-spd)
Trendsetter75 is offline
post #2 of 9 Old 09-07-2013, 10:57 PM
Blakescj7
Well it's just used for towing.
Blakescj7 is offline
post #3 of 9 Old 09-07-2013, 10:58 PM
Blakescj7
Usually people with RVs install them and pull the jeep behind
post #4 of 9 Old 09-07-2013, 10:58 PM
titomars
1981 CJ7
Looks home made to me. It's used to flat tow ones Jeep
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #5 of 9 Old 09-08-2013, 08:10 AM
WindKnot
1977 CJ7
LJ? Isn't that the 4 door Wrangler? Wouldn't THAT be the towing vehicle?
If your vehicle can be flat towed, (check and DOUBLE check your owner's manual) you may need to have one custom made. Another suggestion would be to see what parts are "swappable" with a TJ or JK. Maybe the frame width dimensions are the same. CJ owners lie to parts countermen all the time to get the right part.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #6 of 9 Old 09-08-2013, 08:17 AM
titomars
1981 CJ7
Now that's Priceless !
titomars is offline
post #7 of 9 Old 09-08-2013, 08:21 AM
titomars
1981 CJ7
I will add, automatic transmissions can not be flat towed unless you disconnect the drive line.
titomars is offline
post #8 of 9 Old 09-08-2013, 09:18 AM
jeepwhore
LJ? Isn't that the 4 door Wrangler? .......
Long wheel base TJ: (not mine, pulled the pic from militaryjeepers.com)
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
post #9 of 9 Old 09-08-2013, 05:09 PM
LumpyGrits
NO, it will not fit as the frames are no where close to being the same.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
