identify a "free" 232/58 - JeepForum.com
post #1 of 5 Old 10-19-2009, 04:56 AM Thread Starter
nailedit
1976 CJ7
i'm trying to figure out if an engine is a stock 232 or 58. what are tell tale signs if there are any? The trannys a stock 3 speed. Are all the vacuum lines the same? if theres a thread about this sorry i couldnt find it.
nailedit is offline
post #2 of 5 Old 10-19-2009, 06:48 AM
XJMuscle98
It's basically the same engine, except the 258 is stroked.
So it should look identical.
The only way to be certain would be to measure the stroke or do a compression test.
140 for the 232, 150 for the 258 -- in a perfect world though.
It may not actually help you much if it has lower compression than normal.
1998 Jeep Cherokee 4.0L AW4/NP231 211k+
"Approximately 80 percent of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources."
Ronald Reagan
My goal is to have 20 lights around my XJ.
Currently: 10
XJMuscle98 is offline
post #3 of 5 Old 10-19-2009, 08:16 AM
Pathkiller
1974 CJ5
Here's how to decode the engine numbers and figure out exactly what it is: Jeep CJ VIN / Casting / Production Numbers
Pathkiller is offline
post #4 of 5 Old 10-19-2009, 09:36 AM
JeepHammer
Running On Empty...
1973 CJ5
There are also other signs,
258 often had 2 barrel carbs, where all 232 engines had 1 barrel carbs,
Stuff like that...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #5 of 5 Old 10-19-2009, 09:42 AM
Fjguercio
1978 CJ7
There is a stamped code, passenger side, front of engine & infront of Distributor, and middle of engine is height. There is a small flat milled area, they stamp the engine code there. That will tell is 232 or 258 and it started at 1 bbl or 2bbl. The engine codes are well published.
Fjguercio is offline
I just got 4 Free 39" mickey thompson Tires! CoryA Jeep CJ Forum 8 09-21-2009 04:48 PM
A little "identify that Willy's" trivea. Stacydmcc Jeep CJ Forum 11 07-25-2009 08:43 AM
JKS "Quick" or "Quicker" disconnects? cincyjeeprs Jeep CJ Forum 0 05-15-2009 09:33 AM
Started to tear down the "free" engine, have some questions certifiablejeep Jeep CJ Forum 27 04-24-2009 07:09 AM
"Green Grease" or Lucas "Red N Tacky #2" Curt Reinhardt Jeep CJ Forum 3 07-16-2008 07:09 AM
