Identify Cj5 leaf springs - JeepForum.com
post #1 of 6 Old 09-24-2014, 10:17 PM Thread Starter
PastorGman
Need help in identifying leaf springs on my 1974 CJ5. It has a 3 inch lift kit. Luckily there are some markings on the springs:
Front marking: RT 25105
Rear marking: RT 25115
I removed them to replace bushings. I went to 4 Wheel Parts and ordered some bushings but when they came in they look like smaller in diameter. Need help so I can finish Jeep before cold weather comes in. Appreciate your help. Thanks.
PastorGman is offline
post #2 of 6 Old 09-25-2014, 02:48 PM
PanteraPilot
1978 CJ5
I guess I'm not the only one with problems here. I wanted to replace both top and bottom bushings, but there are a ton off different sizes and little details on how they are different. I emailed Omix Ada hoping the would give me the physical dimensions of their bushings, but the never contacted me back. I'm really struggling trying to find the correct ones.
PanteraPilot is offline
post #3 of 6 Old 09-26-2014, 08:50 AM Thread Starter
PastorGman
Ok, if you go to Energy Suspension website they tell you what you need to measure and even have some links to where they have the sizes available once you have measured. I haven't had a chance yet but think I'm going to call them today. I will let you know by posting later on.
post #4 of 6 Old 09-26-2014, 01:25 PM
PanteraPilot
1978 CJ5
Wow. Great find. Thanks a bunch. These guys look like they've done their research.
post #5 of 6 Old 09-30-2014, 07:50 AM Thread Starter
PastorGman
No luck yet on my end. Went to several places and most of them don't even know the dimensions of the parts they sell. I came across a part: CROJ0921055 it is made by Crown but when I called them even they didn't have the dimensions. I am probably going to order one see if it fits. It consists of a rubber bushing inside a metal sleeve as well as an inner sleeve for the bolt. If anybody out there knows the dimensions for this part I would appreciate your help. Its for a 1974 CJ-5 with 3" lift. The leaf spring number is RT 25115 and RT25105. I was told they were made by Rugged Trail. The part is CROJ0921055 for the bushings.
post #6 of 6 Old 09-30-2014, 12:32 PM Thread Starter
PastorGman
Update: Called an online parts place who called his buddy at Crown and got me the measurements for the CROJ0921055 bushings. Seems like these will work. I ordered two for right now and tomorrow I'll know if I go ahead and order the other six to go all around on the leaf springs. Will update tomorrow.
