Identify this broken part from MC 2100
| GR8TOPS Introduces the Exogate HD Tire Carrier | RUBICON EXPRESS Lift Kits and Accessories Available at Bas | Spartan Lockers FREE SHIPPING Excellent Prices |
#1 | |
Okay, so I'm rebuilding my carb. it's been leaking gas around the base, so I figured I'd just redo the whole thing.
In the process, I found this part broken: ![]() http://i74.photobucket.com/albums/i278/emeraldcite/S5030100.jpg This piece comes between the carb and the block. What is it? It's not in my kit and I didn't find it in my manual. Of course, i could dig around and find out what it is or I can ask of the best collected jeep wisdom on the net. thanks!
#2 |
After some looking around, it looks like an adapter of some kind. It's hard plastic.
I guess the big questions is: do i actually need it? |
#3 | |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Those legs are just through holes for the bolts from the look of it. That would mean it is held in place by compression. I would just use it I think. I might even put some JB Weld or gasket maker or something like that on the crack just before I bolted it back down.
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
#4 |
SEAL Team VI
It's an adapter plate for your carb and yes, you do need it with your 2 barrel MC2100.
It's easy to find replacements.......Summit Racing SUM-G1407 - Summit Racing® Carburetor Adapter Plates - Overview - SummitRacing.com
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, 575 Flex-A-Lite, FlowKooler, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's. |
#5 |
Hockey Rules!
I'm confused by the numer of gaskets you have there that appear to be carb to intake gaskets. I just use one thick "heat isolator" gasket between the carb and the adapter that is attached to the intake. You can get it at autozone, etc. It is a thick cork-like gasket to reduce heat transfer to the carb. The kit probably came with a thin gasket that is all but useless.
Ah... just saw you have a 304... my reference to the adapter is for the 258. |
#6 |
It's called an insulator and yes you need it. Any autopart store should have it cheap and in stock.
#7 |
Sorry, I should have mentioned that I have a 304.
I have the thick cork-like heat isolator (that came with the kit), but do I need the plastic adapter? Both the adapter and isolator were on there. Do I really need both? There were a bunch of gaskets that were on there that aren't in the kit. I don't know if the PO did something weird or not. I just wanted to work on that popping, leaking, flooding, and stalling. Thanks for the advice so far... |
#8 |
Mine was broken too and since it was only a couple of bucks I replaced it.
#9 |
Okay, so it is just an adapter and the only purpose it really serves on my engine is to fill in the length for the intake studs.
Got the carb back on and she started up fine. idled okay. Still have to take her for a ride and adjust, but overall, much better. Now, on to the alternator and voltage regulator... Thanks for the input! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
