ideas needed for original parts for 66 cj - JeepForum.com
post #1 of 5 Old 01-31-2010, 05:53 AM Thread Starter
barlow
1966 CJ5
Hello all, My rig did not come with an emergency brake and I am trying to do my best and find original style parts. Does anyone know of the original E brake design for my dauntless, t-90. A few retailers would also be helpful. Thanks.
barlow is offline
post #2 of 5 Old 01-31-2010, 07:34 AM
hotrod351
1955 M-38
check out ebay. i have a old 55 M38A1 and it didnt come with the emergency brake either. ive seen a few of them on there. the cheapest way is to install a line lock, electric. you know you put the brakes on then flip the switch and it keeps the fluid from going back into the master cylinder. ive thought of doing it on my jeep but really havent had any great need for it as of yet.
hotrod351 is offline
post #3 of 5 Old 01-31-2010, 09:41 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Line locks are not a good idea for parking brakes, especially on older vehicles with iffy wheel cylinders. Any loss of pressure will allow the vehicle to roll, usually at the worst time. E bay, earlycj5.com, or any of the other early cj sites usually has somebody with misc extra stock parts to reinstall the original driveline brake. While much better than hydraulic park brakes, these are still not the optimal option since a lost u joint or other drivetrain part will still keep the system from working. Personally, I would recomend a swap to early Waggy brakes. These 11" brakes are a virtual bolt in swap and will give you not only vastly improved braking, but a rear drum cable operated e brake system as well.
jeepdaddy2000 is offline
post #4 of 5 Old 02-01-2010, 09:06 AM Thread Starter
barlow
1966 CJ5
Great thanks, Should I just measure the run length for the cables and look for parts accordingly? I assume there will be a cable splitter as well to activate both drums. Do you know if the original cj's had a pull up style break or pedal? Thanks again.
barlow is offline
post #5 of 5 Old 02-01-2010, 11:42 AM
OlivergreenCJ7
pull style on the left hand side... drum on the back of the D18...
We Specialize in Willys Jeep parts. CJ Jeep parts, Willys Parts.
1979 CJ7: Gone,but not forgotten
2001 TJ Sport: locked and loaded
OlivergreenCJ7 is offline
Nutter versus fixing the original parts/systems? Ken4444 Jeep CJ Forum 12 01-09-2010 04:03 PM
Suppliers for original and aftermarket parts CarolinaAndy Jeep CJ Forum 4 11-15-2009 09:04 AM
Axle parts help needed, D30 86' busted, friend offering parts for a TJ/LJ D30 Blthomas Jeep CJ Forum 4 10-12-2009 04:17 PM
Frame Coating Ideas Needed jayhawkclint Jeep CJ Forum 11 01-01-2007 03:45 PM
original Jeep parts versus aftermarket parts thejeepfactory Jeep CJ Forum 0 04-16-2002 10:05 PM
