Ideas for an a/c with a serpentine belt 1981 4.2 cj7 258 - JeepForum.com
post #1 of 17 Old 12-27-2014, 11:07 AM Thread Starter
81azcj7
1981 CJ7
I was reading several threads about installing an a/c in a 4.2 cj7. But, I couldn't find any with a serpentine belt. What I have is 1981 4.2 with a serpentine belt, I'm looking for a complete unit to install into the old cj. I've looked at Collins Bros and JeepAir, but theirs is just for v-belts. Anyone have any ideas or run into this before? Thanks
81azcj7 is offline
post #2 of 17 Old 12-27-2014, 11:09 AM
Mike Romain
Maybe check for YJ 258 ones?
Mike
Mike Romain is offline
post #3 of 17 Old 12-27-2014, 11:50 AM Thread Starter
81azcj7
1981 CJ7
I had thought about that too. It seems like it would work, I had called Jeepair, I asked lady answering the phone about it she said they didn't have anything that would work. So, I thought someone on here would have run into the same problem. Thanks
81azcj7 is offline
post #4 of 17 Old 12-27-2014, 08:12 PM
chromegrille
1947 CJ2A
Only difference out of the whole set-up would be the ac compressor clutch.
All 1981 and later CA models were serpentine with Sanden compressor.
Worse case...?....buy one of the kits and change the Sanden compressor clutch?
chromegrille is offline
post #5 of 17 Old 12-27-2014, 08:54 PM
gosupes
California models used serpentine belts and AC. The donor block I rebuilt was from an 81 originally built for California and it had AC and a smog pump. The pump is long gone but the AC compressor is now being used for OBA. The AC was a Sanden pump if that helps.
Opps. I should have read chromegrills post before I hit send.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #6 of 17 Old 12-27-2014, 09:48 PM Thread Starter
81azcj7
1981 CJ7
Thanks for the information, I will call them on monday and see if Sanden has anything available.
81azcj7 is offline
post #7 of 17 Old 01-24-2015, 07:02 PM Thread Starter
81azcj7
1981 CJ7
Bump - I called Sanden and they said they wouldn't have a compressor that would fit on a 81 cj7 4.2 258 with a serpentine belt. Anybody else have an idea as to what would work. I would like to keep it a serpentine, and not change to v-belt. Thanks
81azcj7 is offline
post #8 of 17 Old 01-24-2015, 07:04 PM
Mike Romain
It is a 4.2 and they made them with serpentine belts up to 91. Same setup as far as I have seen.
Mike
post #9 of 17 Old 01-24-2015, 07:59 PM Thread Starter
81azcj7
1981 CJ7
Thanks, when I called Sanden the tech support guy said he had ran into this issue before, but he never could supply the compressor. He said some guys just made something work by shimming, he wasn't too sure. I was looking on their web site and all the 4.2's that they have for wranglers are v belts. I did find that it has a SD7 Direct Short mount. I'm going to look further into it, found some conversion brackets called a york to sanden claw d36. Maybe that will lead me somewhere.
81azcj7 is offline
post #10 of 17 Old 02-26-2015, 07:53 AM
Rolandt03
1983 CJ7
can you not just change the v belt pulley out for a serp. belt pulley? using the same compressor.
Rolandt03 is offline
post #11 of 17 Old 02-26-2015, 08:26 AM
Mike Romain
Not easily or cheaply. You need a different water pump and fan setup as the serpentine has those going in reverse. Then you either need a new PS pump or you can attempt to change the pulley, same for the harmonic balancer and alternator.
Mike
post #12 of 17 Old 02-26-2015, 11:10 AM
Rolandt03
1983 CJ7
I would call jeepair.com there customer service is pretty good. if any one knows how to make it happen they will. they are the original makers of the a/c units. when I installed the 30 year old system in my jeep, it still had the contact info sticker on it. cant remember if they were a diff name or not. they were very helpful just over the phone. have to say, my little unit in the jeep actually works pretty good.
post #13 of 17 Old 02-26-2015, 07:17 PM
frankthomson
frankthomson's Avatar
i have a serp belt on my '86 a/c equipped cj7
i just bought the jeep, but its a Cali jeep originally
..but i think the seller said the a/c was installed w/in the last year????
all i know is when i looked under the hood and saw a serp belt, i was like WTF??!!??
frankrocksjesus.com Want a free cd? PM me!....oh, and im a carpenter, not an auto mechanic, so....
frankthomson is offline
post #14 of 17 Old 02-26-2015, 07:22 PM
Rolandt03
1983 CJ7
Frank.
Post some pics if u can, that would prolly be the most helpful to get this fig out
post #15 of 17 Old 02-26-2015, 07:30 PM
frankthomson
here's the only pic i have right now
4.2 , a/c , ac , aftermarket , serpentine belt
