I6 CJ7 Hedman headers-collector clearance issues - JeepForum.com
post #1 of 4 Old 01-26-2010, 03:00 AM Thread Starter
I6CJ7
I had these headers on my other CJ and have now put them on my new one. The problem is where the 3 collector bolts go in to connect it to the exhaust. The very top hole has pretty much ZERO room to get a bolt in there. I did finally get one in after hitting the crap out of it, but it's a much shorter bolt than the other ones and therefore I cant double nut it to keep it from coming loose like collector bolts do. I have to hold the bolt head with my finger and tighten the nut with a ratchet because there is a bellhousing rib in the way. The only thing I can think to do is grind the the rib and some of the bellhousing off to fit the right length bolt in there and have proper room to tighten it with a wrench. Oh and the collector gasket is leaking because of it. I don't know what the deal is, my other CJ had no problem with this, it was tight also, but I had working room. Also my other CJ had a 4 inch lift as opposed to this one having 2-1/2'' lift. Which thinking about it now may have given me more clearance?
I6CJ7 is offline
post #2 of 4 Old 01-26-2010, 03:57 AM
gmakra
Try this for the collector gasket they work great. Percy's High Performance - Online Store
Then would a 12 point header exhaust bolt with a peened nut work?
gmakra is offline
post #3 of 4 Old 01-27-2010, 06:52 PM Thread Starter
I6CJ7
what does the 12 point header bolt look like? The main problem is I have to hold the bolt head with my finger because it's to small of a space to get a wrench or socket on the bolt head. And the peened nut seems like the way to go, or a nyloc nut, but would the nyloc hold up to the heat?
thanks,
I6CJ7 is offline
post #4 of 4 Old 01-27-2010, 07:18 PM
gmakra
Go with the peened nut since the nyloc will melt. This link will give you reference to what a 12 point header bolt looks like. Mr. Gasket Chrome Header Bolts - JEGS
gmakra is offline
Hedman 69676 coated in frame headers stumper Jeep CJ Forum 0 02-03-2010 11:25 AM
AMC V8 Header Clearance Issues kstopp Jeep CJ Forum 4 02-18-2009 12:22 AM
258 Header Clearance Issues cfljeep Jeep CJ Forum 13 01-25-2009 11:04 PM
Hedman Headers bdmonist Jeep CJ Forum 18 03-29-2007 08:46 PM
Twin stick D20 clearance issues collinpyle Jeep CJ Forum 6 11-05-2006 02:22 PM
