I want On Board Air but... - JeepForum.com
post #1 of 5 Old 09-07-2004, 02:07 PM Thread Starter
fredrader
fredrader's Avatar
1947 CJ2A
I want to install on board air on my jeep but I don't know what to get etc..I am a truck driver and everything I drive has air brakes and air tanks so I can just hook an air hose to a quick connect fitting and I have 120lbs of air pressure..I would like to have the same setup on my jeep but don't know if I can have it..I have seen 12v air setups like for the air lockers but I don't know if they have a tank or what..Any suggestions and how too's would be appreciated..Thanks,Fred
90XJ Limited 4x4,4.0 Auto,NP242
Rustys 4.5" lift D30/D35,3.55 gears
Denman Farmhand Tractor Tires 33x9.50x16
Work in progress
fredrader is offline
post #2 of 5 Old 09-07-2004, 02:34 PM
jadams68
jadams68's Avatar
It's somewhat more involved than that, but relatively painless.
I bought a 2.5 gallon air tank from onboardair.com, however you can get them from Quadratec too. If you want, you can grab a 4 galloon tank from a big rig truck salvage lot too.
All of these tanks have multiple, threaded openings. On my rig they are as follows:
1) Air intake line from compressor.
2) Air output to quick air connect for airing tires, or whatever.
3) Brass plug to block on port off.
4) Safety valve
5) Air release valve.
I bolted the tank through the bottom of my tub under my passenger seat, protected by the frame rail.
Now the compressor I used is a stock Sanden from a jeep cj that had air conditioning. On the intake port I have a small air filter from a lawn mower engine. The out put air hose goes to a manifold.
A manifold is a piece of metal with multiple threaded holes in it. You use this to screw in things like your Pressure Gauge, the hose going to the tank, and most importantly the Pressure Switch. This is what senses that the tank is at 120psi and turns off the compressor.
Email me if you have detailed questions. jadams68@verizon.net
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 5 Old 09-07-2004, 04:02 PM
sircampsalot2
sircampsalot2's Avatar
With all that stuff wouldnt it be just as easy to buy the smallest air compressor you can find that reaches 125psi and bolt it under the seat and then run it off a power inverter? just wonderin
83' CJ7 limited
258 Inline 6
33x12.50x15 Super Sport Radial HT's
Diamond Plate Rockers and Corners
2 KC Daylighters
4" RC Lift
Heavy Duty Steering Shaft
T-4 Tranny 300 Transfer case
[____]
OIIIIIO
[]=o=[] http://img.photobucket.com/albums/v226/sircampsalot2/000_0005.jpg
sircampsalot2 is offline
post #4 of 5 Old 09-07-2004, 04:07 PM
jadams68
jadams68's Avatar
The electric compressors run very hot and have a lower cfm rate which means it would take 3x as long to inflate a 35" tire.
They also cost around 200 bucks... I did mine for about 100.
jadams68 is offline
post #5 of 5 Old 09-07-2004, 05:45 PM Thread Starter
fredrader
fredrader's Avatar
1947 CJ2A
Now thats what i'm talking about
If you have any pics and a few details it would be very helpful as to what I need to go and find and Fab etc..You can email it to fredrader@excite.com or post it..Thanks again...Fred
Work in progress
On Board Air White92 Jeep CJ Forum 78 04-22-2015 11:17 AM
On Board Air You Didn't Know You Had Oily Jeep CJ Forum 19 03-15-2009 09:45 PM
Need help with on board air coyote69 Jeep CJ Forum 6 07-20-2007 04:34 PM
New To The Board Double AA Jeep CJ Forum 2 09-27-2004 07:46 PM
Help w/ on Board Air set-up steve1244 Jeep CJ Forum 2 03-04-2003 10:49 PM
