I need a transfer case shifter lever for my CJ - JeepForum.com
post #1 of 16 Old 09-07-2002, 01:43 PM Thread Starter
jeepin cj-5
Does anyone know where to find the shifter lever for the transfer case on a CJ-5 .. i rebuilt my trans and now i am missing that lever.
jeepin cj-5 is offline
post #2 of 16 Old 09-07-2002, 07:50 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
southern Oregon 4x4. 1-541-826-3149.
jeepdaddy2000 is offline
post #3 of 16 Old 09-07-2002, 09:22 PM
rebelcj7
not to be an A$$ but it would hlep if you listed what t case you had, is it stock? or did yuo swap in one of the millions of t cases around? that would deff help there buddy
Big n fugly 78 cj7.. built baby built
51 willy's in the process...
**MoROC Presidient**
rebelcj7 is offline
post #4 of 16 Old 09-07-2002, 10:21 PM Thread Starter
jeepin cj-5
Well if it was aftermarket I would make a note of that.... me not making any note means it is given that it is stock.
post #5 of 16 Old 09-08-2002, 09:48 AM
rebelcj7
Being aftermarket or not has nothing to do with it, if you said aftermarket id think atlas, but you simply said t case, which could lead to any one of them.
If you had said STOCK then thats cool..
ok so you got a d 20 a and you want stock replacement or aftermarket? if you want stock, you can find em about anywhere..
as far as aftermarket a buddy of mine makes the twin shift kits for the d20, check him out, i think there 100 bucks..
Missouri 4 Wheelers Supply D20 Twin Shift Kits
rebelcj7 is offline
post #6 of 16 Old 09-08-2002, 04:44 PM
CSP
Just because it's a CJ5 does not limit it to just one available shifter. It could have a Dana 20 or a Dana 300 depending on the year. Neither use the same shifter. The Dana 20 can have two different types of shifters also. You wanted us to assume that it wasn't aftermarket just because you assumed that all stock were the same. Don't assume anything and provide all pertinent info!
CSP is offline
post #7 of 16 Old 09-08-2002, 04:57 PM
rebelcj7
Exactly my point, no single brand of vehicle came with only one certain t case, some 5's also came with d18...
while, when someone does say 5, i usually assume a d20, it came with the majority of them.
try the year of the vehicle, tranny, t case etc, and jus becvause u havent swapped em out, and when u bought the jeep u were told its stock dont mean its stock for that specific year vehicle, a lil more info would certainly help out..
And as for the d20 having 2 types of shifters, yes that is true, but int he cj5 or7, if it is STOCK d20 they are the same shifters, only difference in them is when u go to fsj's
rebelcj7 is offline
post #8 of 16 Old 09-08-2002, 09:18 PM
CSP
Very true. As you mentioned a prior owner could have swapped anything in. That's why I mentioned it. I didn't even think about pre-72 CJ's or the Dana 18.
CSP is offline
post #9 of 16 Old 09-08-2002, 09:22 PM
rebelcj7
CSP, Yeah i had forgotten bout the 2 types until you mentioned it also.. and the different types, i forget as well at times..
so again, jeepin dood, what t case u got??
rebelcj7 is offline
post #10 of 16 Old 09-16-2002, 10:09 PM Thread Starter
jeepin cj-5
Sorry Fellas didnt mean to come off so ignorant...I am noy sure at this point what case it is but it is stock running behind a t-14 trans...I dunno if this means anything but i was mainly just lookin for a site.. I will find out which case it is shortly.
post #11 of 16 Old 09-17-2002, 05:35 AM
Bulletproofcj7
http://www.off-road.com/jeep/swb/articles/specgrid.htm
Heres a site that may help you identify what you have, complete with pictures.
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #12 of 16 Old 09-17-2002, 09:37 AM
CSP
Well the easiest thing you can do is tell us what year the Jeep is. So far you still haven't done that. The T14 helps narrow it down, but it was used with two possible transfer cases. The '72-75 CJs with the T14 will have a Dana 20 behind them. Older than '72 CJ's with a T14 will have a Dana 18 behind them. If your original post had included the year you could have had an answer by now.
CSP is offline
post #13 of 16 Old 09-17-2002, 07:54 PM Thread Starter
jeepin cj-5
Ok the reason I sound so worthless is that my jeep aint at my house, its at my grandfathers so I cant look at it. I do know this, its a 72 CJ5 with a T-14 trans.
post #14 of 16 Old 09-19-2002, 08:29 AM
redhat6161
www.oly4x4.com
anything you want, got a hard to find t-18 shifter from them
redhat6161 is offline
post #15 of 16 Old 09-20-2002, 06:23 PM Thread Starter
jeepin cj-5
Does anyone know how to decide what kind of case it is by the numbers on it? I never got any numbers that said exactly like d 20 I am clueless. How do I tell?
4wd shifter came out of transfer case rcawrse Jeep CJ Forum 3 12-30-2009 01:25 PM
transfer case shift lever... Dana 300 jlr69s Jeep CJ Forum 8 05-15-2008 07:50 AM
Transfer case, the big shifter, the little shifter, and oddness senaTTor Jeep CJ Forum 10 10-17-2006 06:52 PM
Transfer case shifter bzzdagok Jeep CJ Forum 2 01-01-2004 04:24 PM
