i need a source on a transmission cable - JeepForum.com
post #1 of 4 Old 07-12-2012, 06:57 PM Thread Starter
John87
this was my FIRST time wheeling my cj.
i melted the transmission shifter cable on my jeep today. it was rubbing against the header and melted through. of course i was off roading and came to a dead end, stopped, then couldnt shift into reverse, or any gear, and had to have my buddy jake tow me out backwards with his jk unlimited. i wasnt able to shift out of park, and discovered this. after it cooled off i wrapped it in electrical tape, then gorilla tape, bam, it worked. i used the tape to re-create the sleeve. this is what the tape looked like after about 45 more minutes of driving home. i think the gorilla tape held up pretty good.
so, where would i find a cable, the trans is the TF999, and it has the POS B+M shifter in it. and yes, this is just the excuse i need to swap my cj back to a 4spd, but unfortunately its been a dry summer and the money tree is shriveled up.
this is the only thing ive been able to find, but it says it wont work on the TF999
http://www.quadratec.com/products/80814.htm
-John
°llllll° 1985 CJ-7
John87 is offline
post #2 of 4 Old 07-13-2012, 08:57 PM Thread Starter
John87
bump
-John
°llllll° 1985 CJ-7
John87 is offline
post #3 of 4 Old 07-13-2012, 09:19 PM
VACJ7
VACJ7's Avatar
Not sure why they say will not fit the 999. It fits the 904 and the 904 and 999 have basically the same case. Anyway, if it were mine I would look for a part number on the cable and/or call B&M directly with the model shifter and see what they say. Did you check their web site for a replacement? Summit also has universal cables. http://www.summitracing.com/parts/BMM-80604/
'84 CJ-7 |
VACJ7 is offline
post #4 of 4 Old 08-21-2013, 09:04 PM
rksnow1
Hi, I know this is a Year old post but did you ever find the shift cable you needed. I just did a TF999 swap into my jeep and am looking for the same cable but not having any luck. Any part number, manufacuter ect would be helpful.
thanks again
rksnow1 is offline
Heater cable question: What is this cable called? jatepper Jeep CJ Forum 6 11-28-2011 09:41 PM
Cable Operated Clutch - Need new cable 028346 Jeep CJ Forum 5 06-24-2011 11:26 PM
86 CJ7 Inline 6, T5 Transmission Speedometer Cable Problem chieffatboy Jeep CJ Forum 9 06-12-2010 11:05 AM
Transmission Cable Hook Up BULLITTBUilder Jeep CJ Forum 5 10-21-2009 09:41 AM
Transmission bearing puller source? hfjeff Jeep CJ Forum 2 01-20-2007 04:03 AM
