I need some cheap All Terrain Tires. Suggestions? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > I need some cheap All Terrain Tires. Suggestions?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO
Unread 12-02-2014, 02:21 PM   #1
Balvar24
1979 CJ7
I know cheap tires suck.
I want tires that are cheap. I'd like some All Terrain-ish looking tires. I understand they may suck.
No more miles than my Jeep sees, I'm expecting them to rot long before I wear them out.
Any suggestions?
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline   Reply With Quote Quick reply to this message
Unread 12-02-2014, 02:24 PM   #2
RedNeckCorvette
1979 CJ7
Watch Craigslist you will find them.
RN
RedNeckCorvette is offline   Reply With Quote Quick reply to this message
Unread 12-02-2014, 02:30 PM   #3
WillieWildcat
I put some tires on my old truck from tirerack.com. They're retreads, but have held up well so far. I picked up their blemishes (i.e. factory seconds) for about $60 per tire (shipped) and had the same tread pattern as the BFG All-terrain TAs.
edit: treadwright.com, not tirerack...
2005 Wrangler X, 4.0L I6, 65k
1997 F-250 LD, 4.6L V8, 245k
1992 Cherokee Laredo, 4.0L I6, 174k
WillieWildcat is offline   Reply With Quote Quick reply to this message
Unread 12-02-2014, 06:10 PM   #4
CSP
Treadwright
CSP is offline   Reply With Quote Quick reply to this message
Unread 12-03-2014, 03:32 PM   #5
WillieWildcat
Originally Posted by CSP View Post
Treadwright
Wow, that's totally what I meant to type. I've never bought a thing from tirerack...
Unread 12-03-2014, 03:48 PM   #6
wm69
Retreads, or get some BFG AT's. Discounttiredirect will ship free, no sales tax, and do 0% financing for 6 months so you can do a little at a time without paying interest. I normally don't finance anything, but passing on 0% financing doesn't make sense.
wm69 is offline   Reply With Quote Quick reply to this message
Unread 12-03-2014, 04:27 PM   #7
penster1
1980 CJ5
Tires
I bought 4 31 10x15 tires at pep boys 2 years ago for around 90. Per tire. So far so good. Never been stuck in them.
penster1 is offline   Reply With Quote Quick reply to this message
Unread 12-03-2014, 08:52 PM   #8
turpehar
turpehar's Avatar
1977 CJ5
If you are going with new I would suggest giving a look at the new Mastercraft Courser ATX all terrain, OR the Falken Wildpeak. The mastercrafts are cheaper than the Wildpeaks but they are also not as hard. Both are 50k tires. Im putting a set on a customers TJ in 235x75x15 out the door mounted, balanced, taxes, and fees for $510.
I run the Wildpeak in 315x75x16 on the wifes Super Duty and they are by far the best tire I have ever used on any truck I've ever owned. I also have a set of 31x10.50x15 on one of my Cherokees. I used to run a mud tire but I was running through them too quickly.
I have learned a lesson about the BFG A/T. I won't buy them again. I had two successive sets on my other Cherokee and they would balance out but always bounced at 45-50mph. I know you are thinking this was death wobble but I had completely rebuilt the front end. Upper and lower adjustable control arms, unit bearings, adjustable track bar, tie rod end, axles joints, and ball joints, fully aligned. still had the bounce. I had a set of Treadwrights that were better than the BFG.
hth
I've been married so long I don't bother looking
both ways before crossing the road.
(Trial + error)*Upgrades) - $² = (mac-n-cheese/hot dogs)+experience
https://www.facebook.com/CentralILOffRoad
http://centraliloffroad.com/
turpehar is offline   Reply With Quote Quick reply to this message
Unread 12-04-2014, 05:27 PM   #9
CrankyD
1983 CJ7
I have had really good luck with my Goodyear Wrangler Authority tires from WAL-MART! They only came in 31x10.50x15 though.
CrankyD is offline   Reply With Quote Quick reply to this message
Unread 12-08-2014, 06:29 PM   #10
strvger01
1966 CJ5
another vote for Treadwright. I've been running them for more than 10 years. good tires at good prices.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline   Reply With Quote Quick reply to this message
Unread 12-10-2014, 02:17 AM   #11
holliewood61
1981 CJ7
X2 on the falken wildpeak. I run them in a 305/70R16 on my f-150. They look rather tame but they do surprisingly well off road, extremely in the snow, and on wet roads. It will be the next set that goes on my tj. If my cj spent more time on the road it would be wearing them as well.
08 WK bone stock
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline   Reply With Quote Quick reply to this message
Unread 12-10-2014, 06:57 AM   #12
auburnhunter
Maxxis Bighorn. I got a set from Pep Boys but I see they aren't offering them anymore. I am a cheap tightwad, so these are the cheapest you will find without going retread. I didn't like the tread design on the Falken.
"The problem with quotes on the internet is that you never know if they are real or not" - Abraham Lincoln
auburnhunter is offline   Reply With Quote Quick reply to this message
Unread 12-12-2014, 10:19 AM   #13
turpehar
turpehar's Avatar
1977 CJ5
http://www.fourwheeler.com/how-to/11...n-tire-review/
