I Need a picture of some Air Cleaner parts - Page 2 - JeepForum.com
post #16 of 30 Old 06-29-2012, 10:58 AM
Jon In Tucson
Jon In Tucson's Avatar
1983 CJ5
PM sent
Happen to find the washer anyplace.
I think I can pound one of those out though.
Couldn't find that washer any place. Actually cleaned the top of my bench. It was blue, just as one of the pictures... If it turns up I'll let you know. God bless.
Jon In Tucson
Jeremiah 17:7 "But blessed is the man who trusts in the Lord, whose confidence in Him."
"The secret to a Jeep, especially a CJ, is you can't
panic." - Mike
"I may not be a smart man, Jenny, but I do know grounds."
Jon In Tucson is offline
post #17 of 30 Old 07-02-2012, 06:32 PM Thread Starter
John Strenk
John Strenk's Avatar
1976 CJ5
Just got the parts today. Thanks!
Now I'll be able to put it on the correct way.
John Strenk is offline
post #18 of 30 Old 07-09-2012, 11:17 AM
FLynes
1976 CJ5
No. Need one?
Actually, yeah I do. Mine is boogered up.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #19 of 30 Old 07-09-2012, 04:13 PM Thread Starter
John Strenk
1976 CJ5
I got the one I pulled off. It's dirty but worked fine.
post #20 of 30 Old 09-25-2012, 04:43 PM
Ollie09
1983 CJ7
Anyone have one of these to sell? I need one.
Originally Posted by budblind View Post
If you need it your welcome to it...
Just pm me with an address to send it and I will box it up. God bless.
Jon In Tucson
Ollie09 is offline
post #21 of 30 Old 09-25-2012, 06:43 PM
VaCJ79
1979 CJ7
Looking for parts as well. I need 14, 17 and 23 and may need more... anyone know if you can still get these. Going to try the local dealer which I suspect will not have them.
1979 CJ7 258 / 4.0 head / J20 power Steering / T150 Dana 20 / EMU YJ 2" lift / Custom front bumper
Looking for : Please PM, Carter 2 barrel Carb before you through it out
VaCJ79 is offline
post #22 of 30 Old 03-11-2013, 11:04 AM
drespecki
1983 CJ7
I am in need of this mount also.. actually, everything except the mount!
14, 15, 17, 18, and 19 in the parts diagram... I have 16 which is the actual mount..
Dennis in Tucson...
It only hurts while you're breathing..
drespecki is offline
post #23 of 30 Old 01-02-2015, 07:34 PM
Dolf
[/QUOTE]
The PO put on an air cleaner about half the size of a beer can. I've got a Carter BBD. I'm looking to put on a K&N air cleaner but I need part number 5, the air cleaner hold down bracket do-hickey. Anybody know what it's really called and where I could find one? Thanks
Dolf is offline
post #24 of 30 Old 01-03-2015, 04:21 PM
cwig12
1983 CJ7
I went to the hardware store and just pieced those parts together for cheap. Autozone even had a few select parts.
Creative-X - Web Design and 3D Printing
My portfolio:
cwig12 is offline
post #25 of 30 Old 01-03-2015, 07:29 PM
STJP
STJP's Avatar
Part numbers, hardware store pictures.................please..............:conf used:
STJP is offline
post #26 of 30 Old 01-03-2015, 08:06 PM
Dolf
In the image, there is a part illustrated as part #5. Itís an upside-down ďUĒ shaped bar with a bolt that goes through it. The air cleaner cover goes through it and holds the cover down. When I look at Carter BBD illustrations, it doesnít give this part name/listing, and I canít find it in the air cleaner section of the 1982 Jeep manual. Whatís it called? Where can I get one? Junk yards are slim pickings for something like this. Thanks.
Dolf is offline
post #27 of 30 Old 01-04-2015, 02:05 AM
cwig12
1983 CJ7
I'll post pics tomorrow but you can buy air cleaner rods at autozone as well as the wing nut to tighten it down. I took a flat bracket with a pre drilled center hole for the air assembly to sit on. That bracket sits on top of an oversized wingnut flipped upside down because I run a weber carb so I had to boost it up a bit. A couple nuts to hold the rod in place and you're good to go. I think it ran me less than $10 and it holds the air assembly nice and steady.
Pictures will make it a lot easier to understand. I just got back from a bar and can't post pics from my phone so I'll edit them in tomorrow.
Edit: I read the other post by drespecki wanting the parts for the air cleaner sitting on the valve cover. The U that goes on the Carter is a whole other story. If all else fails I can see what it would cost to have one 3D printed out of stainless steel and add it to my store.
My portfolio:
cwig12 is offline
post #28 of 30 Old 01-04-2015, 10:20 AM
Dolf
The Carter BBD carb does not have the center air cleaner hold down post that goes through the butterfly like many other carbs do. It has a bracket that clips to either side of the carb. People have suggested using a coat hanger and bending it around a 1/4 x 20 bolt, but their coat hangers must be made a lot stouter than the ones I have. If I made one like that, sure enough it would fail at he farthest point away from civilization on the trail. Rod from the hardware store breaks when you bend it too much. Auto manufacturers used this same hold down on slant-sixes, but those are rare around the salvage yards around here.
Dolf is offline
post #29 of 30 Old 01-04-2015, 10:59 AM
cwig12
1983 CJ7
I have one sitting in a box with my old Carter that I pulled off a while ago, keeping it for backup if I ever need to pass emissions.
It might be in your best interest to pick up any Carter 2BBL on Ebay and salvage the original U. I see them on Ebay for $15 all the time, it will work a hell of a lot better than a coat hanger.
Ebay Carter 2BBL with U
My portfolio:
cwig12 is offline
post #30 of 30 Old 01-04-2015, 11:59 AM Thread Starter
John Strenk
1976 CJ5
Welding rod is a bit bigger and still easy to shape. I have one BBD with one like that on it.
Air cleaner parts VaCJ79 Jeep CJ Forum 15 11-01-2011 08:05 PM
Wanted: Parts Book Blow Up Picture of 76-86 CJ Windshield Frame & Internal Parts audioresearch Jeep CJ Forum 3 05-26-2010 12:40 AM
Air Cleaner Parts Jonesie Jeep CJ Forum 2 05-06-2010 06:45 PM
Air Cleaner Vacuum Help - See Picture OldSkull Jeep CJ Forum 6 09-28-2009 08:47 AM
258 Air Cleaner Decal Location - Picture Request mrdibbles Jeep CJ Forum 3 06-06-2009 11:07 PM
