I Need a picture of some Air Cleaner parts - JeepForum.com
post #1 of 30 Old 06-27-2012, 03:01 AM Thread Starter
John Strenk
John Strenk's Avatar
1976 CJ5
I had adapted my Air cleaner housing to fit my YF carb which made me modify how it mounts to the Valve cover.
Now that I put a BBD on the engine the Air cleaner sits to High and won't seal against the carburetor correctly.
I don't have the original stuff anymore so if someone can take a picture and maybe some measurements of the slider, I would appreciate it.
These parts:
John Strenk is online now
post #2 of 30 Old 06-27-2012, 10:07 AM Thread Starter
John Strenk
1976 CJ5
Bump....
post #3 of 30 Old 06-27-2012, 10:19 AM
Jon In Tucson
Jon In Tucson's Avatar
1983 CJ5
John,
I think I have the part you're looking for... If I can find it in my junk pile called my shop you are welcome to it. God bless,
Jon In Tucson
Jeremiah 17:7 "But blessed is the man who trusts in the Lord, whose confidence in Him."
"The secret to a Jeep, especially a CJ, is you can't
panic." - Mike
"I may not be a smart man, Jenny, but I do know grounds."
Jon In Tucson is offline
post #4 of 30 Old 06-27-2012, 10:24 AM Thread Starter
John Strenk
1976 CJ5
Thanks!!
post #5 of 30 Old 06-27-2012, 10:49 AM
86cj74.2L
86cj74.2L's Avatar
I've bought them new from the dealer about 8 years ago........ The nut, stem, and little holder for the nut that clips in the bracket on VC........if you have no luck.
86cj74.2L is offline
post #6 of 30 Old 06-27-2012, 10:50 AM
86cj74.2L
86cj74.2L's Avatar
Your going to get flack for that upgrade........
post #7 of 30 Old 06-27-2012, 11:30 AM Thread Starter
John Strenk
1976 CJ5
Nah..
post #8 of 30 Old 06-27-2012, 12:15 PM
scrapman
I don't have dimensions, but here is a pic I found when looking for the same part. I now have a cheap 8" open element air cleaner.
scrapman is offline
post #9 of 30 Old 06-27-2012, 01:22 PM
FLynes
1976 CJ5
John, did you get rid of your YF?
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #10 of 30 Old 06-27-2012, 04:10 PM
lugnut28
lugnut28's Avatar
I just dropped off my parts to have them zinc plated. Should have them back in a day or so. When I get them back, I'll take some measurements.
lugnut28 is offline
post #11 of 30 Old 06-27-2012, 04:39 PM
keith460
Jeep. There's Only One
keith460's Avatar
Here's what I have John for a stock setup air cleaner for Jeeps equipped with power brakes. I had to use 1" spacers to raise the valve cover bracket in order to use the OEM air cleaner when I converted the Carter BBD with a Weber 32/36 carb.
1984 CJ-7 Renegade
keith460 is offline
post #12 of 30 Old 06-27-2012, 06:57 PM Thread Starter
John Strenk
1976 CJ5
No. Need one?
post #13 of 30 Old 06-27-2012, 07:03 PM Thread Starter
John Strenk
1976 CJ5
Wow. Thank for the pictures.
My air cleaner mount is welded to the valve cover. I had to lengthen the notch to fit the YF carb and my flat little domed washer thing is about 1" high.
I user a carriage bolt to hold it down but if I had not notched it, it probably would not fit in.
post #14 of 30 Old 06-28-2012, 09:59 AM
Jon In Tucson
1983 CJ5
Found it!
Originally Posted by budblind View Post
John,
Jon In Tucson
If you need it your welcome to it...
Just pm me with an address to send it and I will box it up. God bless.
Jon In Tucson
panic." - Mike
post #15 of 30 Old 06-28-2012, 10:04 AM Thread Starter
John Strenk
1976 CJ5
PM sent
Happen to find the washer anyplace.
I think I can pound one of those out though.
Air cleaner parts VaCJ79 Jeep CJ Forum 15 11-01-2011 08:05 PM
Wanted: Parts Book Blow Up Picture of 76-86 CJ Windshield Frame & Internal Parts audioresearch Jeep CJ Forum 3 05-26-2010 12:40 AM
Air Cleaner Parts Jonesie Jeep CJ Forum 2 05-06-2010 06:45 PM
Air Cleaner Vacuum Help - See Picture OldSkull Jeep CJ Forum 6 09-28-2009 08:47 AM
258 Air Cleaner Decal Location - Picture Request mrdibbles Jeep CJ Forum 3 06-06-2009 11:07 PM
