I need a part!!!!!!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > I need a part!!!!!!!!
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 12-20-2008, 09:58 PM   #1
stephens_cj5
1981 CJ5
This is most likely the wrong section but I am having a difficult time finding these parts. More traffic in this section.
I need the adapter that holds the bracket for the steering column. Its part number J535 5544. Putting the jeep back together and I can not find this part While I'm at it I need the clip that holds the rod (for the hood) in the closed position.
1981 CJ5 ground up restro in progress, finished product will have: 4.2 w/ a 4.0 head conversion, headers, Howell TBI, HEI, D300, AMC 20, D30, 3" lift w/ 33x12.50 BFG. All new hardware, all diffs rebuilt.
stephens_cj5 is offline   Reply With Quote
Unread 12-20-2008, 10:05 PM   #2
John Strenk
John Strenk's Avatar
1976 CJ5
That would be #6 for those who don't know what J535 5544 is...
John Strenk is offline   Reply With Quote
Unread 12-21-2008, 01:25 AM   #3
OldSailor
1977 CJ7
For those hard-to-find obsolete CJ parts, try Walck's 4WD at http://www.geocities.com/MotorCity/Shop/1658/
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc.
OldSailor is offline   Reply With Quote
Unread 12-21-2008, 05:55 AM   #4
Oily
Not my prop rod clip but available on Ebay.
Oily is offline   Reply With Quote
Unread 12-21-2008, 06:32 AM   #5
keith460
Jeep. There's Only One
keith460's Avatar
Here's a better pic of actual part:
No, it's not for sale and no, you can't have it!
keith460 is offline   Reply With Quote
Unread 12-21-2008, 07:19 AM   #6
mcmud
1983 CJ8
For the hard to locate OEM parts contact Charles or Amy at Jackson and Son Jeep Parts in Talledega, Al. This is a Jeep salvage yard started by Charles's father way back in the nineteen hundreds.
Kind folks with extensive knowledge. Phone them at 256 362 7772.
mcmud is offline   Reply With Quote
Unread 12-21-2008, 08:59 AM   #7
fredrok
Phil at Max-Bilt was able to help me out with used stuff.....
If you don't have time to do it right, how will you ever find time to do it again?
fredrok is offline   Reply With Quote
